Trac, vsc, abs, red triangle
Old Jul 10, 2019 | 10:39 AM
Antc2's Avatar
Antc2
Default Trac, vsc, abs, red triangle
Ik I posted it before but I checked the battery and alternator and they are fine, and I scanned my car and no codes pop up. And when the weather is cold outside all the lights are off.
its an 2006 gs300
Old Jul 10, 2019 | 11:20 AM
Antc2's Avatar
Antc2
its an 2006 gs300
And my brake light is on too
Old Jul 10, 2019 | 11:24 AM
mspearl95's Avatar
mspearl95
Brake actuator/pump?
Old Jul 10, 2019 | 12:01 PM
ibidu1's Avatar
ibidu1
I think you may just have a bad wheel speed sensor. These sensors measure the mph of each wheel, and theyre located inside the wheel hub. A bad sensor would make the traction control go crazy, when you brake the abs will go nuts aswell, etc.
You can inspect your sensors, try disconnecting them and reconnecting them. You might get lucky and find corrosion in the terminal. But you need a good scan tool that can measure the wheel speed mph from each sensor. This will tell you if you have an issue, because a wheels sensor will be offline or throwing out a bunch of crazy numbers.
Old Jul 10, 2019 | 12:02 PM
ibidu1's Avatar
ibidu1
Thats rare on a gs300, as they run the gs350 style abs system. Unlike the 430/450/460
Old Jul 10, 2019 | 12:29 PM
tghw's Avatar
tghw
Doesn't have one.
Old Jul 10, 2019 | 12:44 PM
mspearl95's Avatar
mspearl95
Ah cool! Good to know.
Antc2
Jul 7, 2019 10:49 AM
Smokie
RX - 1st Gen (1999-2003)
Feb 18, 2018 08:35 PM
GS300freak
Dec 15, 2017 01:55 PM
Gunnut
Oct 22, 2011 05:54 PM
smokincigs
Apr 10, 2011 12:47 PM
