Gs350 stop hesitation
Hello guys, today I noticed that my car is hesitating a bit while stopped and slightly letting the brake go. I can think of probably of fuel filtering needing replacement? If so does anyone have a guide or can tell me it's location?
Thanks in advance guys!
I would put the car on a scanner and scan the fuel trims.
Theres only one filter/screen in the gas tank attached to the pump. You can remove it and clean out the screen with a good parts cleaner spray. Cleaning the throttle body inside and out will help, doing a full bottle of seafoam through the intake manifold vacuum line will also help.
Mine is RWD, I did a intake cleanup last year Guess I will do again, the seafoam through the intake will require changing the spark plugs, i can try that, I think I have my old spark plugs stored somewhere..
Its worth mentioning that recently I changed my intake tube to the one that comes in the 2013 GS 350 F sport, the one with the sound generator, probably that could be the problem? Also worth mentioning that the car does it only when its cold, when you drive for some minutes it gets away significantly.
Yes, on februsry my car had a transmission leak through work out transmission pan seal and the transmission was overhauled and fresh fluid was out inside.
