what repairs on front end suspension have you guys done
Old 09-17-18, 09:07 PM
ibidu1
ibidu1's Avatar
Originally Posted by RXGS
The OEM awd strut for the fronts is only a few dollars more than the KYBs when i replaced mine, it was like only 30 bucks more for the pair over the KYBs
Awhile back KYB didnt even sell aftermarket for awd, only the is250awd, but the valving was different. Now they offer it, and its pretty cheap! $62 per side and theres a rebate (expires soon) on rockauto.com. Oem retails for $200 per side
KYB is the same as oem, theyre the oem supplier for toyota/lexus
Old 09-17-18, 09:21 PM
kngstonboi
kngstonboi's Avatar
yes, definitely start by taking a look at your struts. I was having a similar issue and replaced both struts and shocks; ride quality was restored
Old 09-18-18, 09:47 AM
gr8fulRed
gr8fulRed's Avatar
I'm at 155k and have been thinking it may be time to start looking at suspension components to replace. The only thing i've seen while inspecting things is a torn boot on the strut (i believe). Are most of these suspension components DIY friendly...or do they require special tools, etc??
Old 09-18-18, 04:11 PM
RXGS
RXGS's Avatar
I paid $90 per side for OEM struts for my AWD from MyLparts with a 5% discount, about 2 years ago.
Old 09-18-18, 06:58 PM
verly6565
verly6565's Avatar
i found this
LexNYC83 (03-26-19)
Old 09-20-18, 07:58 PM
Propulsion
Propulsion's Avatar
Originally Posted by nobelnabil
My car is 130K miles and I didnt see anything fail so far except for a ripped CV boot. you can always inspect the following.
-check CV boots for rips.
If the CV boot is ripped does that automatically mean the CV joint needs replacing?
Old 09-21-18, 11:06 AM
tghw
tghw's Avatar
Not necessarily. It depends on whether any dirt, moisture, or other contamination got inside and contaminated the grease/joint. If that happens, it will eventually damage the bearings in the joint itself. It's best to replace a damaged boot asap
Old 09-24-18, 03:30 AM
samsonn25
samsonn25's Avatar
Originally Posted by verly6565
how did the bearing look,also could you push the strut in
Oops sorry, I was talking in relation to my BC coil overs that I replaced them with. They dont use a bearing they use a metal sleeve inside the rubber in the upper strut mount plate.
Old 09-26-18, 09:45 AM
ibidu1
ibidu1's Avatar
Those videos you posted only the 3rd is for AWD, as the AWD vs RWD have different mounting setups.
Old 09-27-18, 03:41 PM
verly6565
verly6565's Avatar
it just to give a idea
lexslexus
09-12-17 04:52 PM
nuck
09-07-16 10:15 AM
artbuc
05-18-16 06:41 AM
Jbthompson
12-25-15 03:19 AM
DREGS3
Suspension and Brakes
12-03-14 06:19 AM
Quick Reply: what repairs on front end suspension have you guys done
