Spark plug change
What are you guys using for spark plugs
mine is a 2010 gs350 awd
1- are you using oem
2- can you use other brands
3-is it faily easy job
4 what should i look out for
5- if you have any links can you post them
thanks guys
thanks guys
1) Nope\Yes
2) Yes, I'm using DENSO 4705 Iridium TT. Same Twin-Tip design as the OEM but way cheaper than the dealership. DENSO is OEM
3) It's fairly easy. Driver side is easy to work on, the Passenger will be a bit more involving. You will need to remove the intake.
4) Just take your time. I didn't run into anything major.
5) I bought all my stuff from rockauto.com.
There is also a rebate, I got an $18 gift card. AA PMED RA with 5% discount (I sent them a screen shot). AA is an authorized denso dealer, so no fakes, peace of mind.
2- Not suggested, but there is another denso plug which cost less. I have it in other cars and it works well. Supposedly gives a bit more performance(thinner fire area), but supposedly isn't sold as long life. If you are on a budget, a good choice though. Lexus dealer here said NGK would also be an option, but they are actually more expensive. Copper and Plat is available, but not a good idea in my opinion. If they are suggesting 60K intervals with iridium plugs, those probably have a very short life.
3- I thought it was very easy, there some 4gen yt vids but it is identical. There is just a bracket to remove on the driver side with a few nuts and bolts. I also cleaned the TB, use a minimal amount of carb cleaner on a brush and tilt away from the electronics side.
4- I use a torque wrench, I am from the Ford world where spark plug torque is very critical. Good idea here too because it will make them easy to change again. These are crush plugs unlike other makes tapered seat. I believe 18-20ft\lbs (saw +- 3 from that number in places). I also put a bit of silicon lube on the inside of the coil boots and on the head grommet, I worked for Ford and was always told to do that. Purpose is to displace any moisture, and make it easy in the future to remove. That is probably optional though.
5- You can search yt for GS350 plugs.
Size? Standard spark plug socket that works on Fords and tons of other cars :lol:.99% sure it is 5/8'ths.
That being said, if you keep an eye on things coppers WILL likely work. Some performance enthusiasts insist on copper because of conductivity and performance. Despite being cheap, they are probably the best (but short lived). Make sure the gap is correct. I know I have some small engines though, and they didn't run well when I tried a long life plug. The old plug ran and started perfectly afterwards. You have to try, you can always exchange them in advance auto.
From some cursory research, copper is 3x more conductive than Iridium and 6x Platinum. Cu is great at heat dissipation too. In the real world, that means very little though. Cu may give an extra 1/2 - 1 hp.
The link in the third message I posted will get you the plugs, use WELCOME code when you sign up for speedperks to get $30 off. If not there are other coupons if you search. You also have a rebate offer.
