Memory Seat buttons do not work
Hi All,
I purchased a 2006 GS300 not too long ago which has been working out pretty good so far. Besides a worn out radiator cap and bad TPMS sensors, I haven't had any major issues with the car except the power seats memory buttons. They seem to not do anything on both the driver and passenger when making adjustments while in parked. Are they supposed to beep when you press them? I've made major adjustments and then set the memory number. I then change the seating position dramatically and then press the #1 but nothing happens. Seems like they aren't responding at all. Would you happen to know where the fuses are located for the seats? Thanks in advance. I have soaked up so much from this forum and I'm glad to see it's alive and active!
Try while parked pressing both set and 1 at the same time. If it makes a beep then the seat setting is saved. Try adjusting the seat afterwards and pressing 1 to see if it works. I thought mine didn’t work when I first bought the car but I was not saving the setting correctly.
So what I was doing wrong was pressing set first and then pressing 1. I needed to press and hold set first and then press 1 simultaneously which I heard the beep afterwards. Thanks for the help!
