AWD driveline damages?
Hello all and thanks for thinking about this and sharing any ideas you may have. Most of this is back-story / explanation. Skip on down to bottom to get cliff notes starting at "SYMPTOMS":
I have a 2010 GS 350 awd with 92k. It has been lowered on Megan Racing C/O's and 20" wheels/tires. Wheels are 9" wide in front, 10.5" in back. I have 245/35/20's on the front with 275/30/20's on rear. It has been setup like this since about 45k miles (about 4 years) with no real probs (slight rubbing until proper ride height dialed in and the all-too-common vibrations at stop/low speed wobble - lived with it a while).
Many more mods but those are the applicable ones for the purpose of this thread. Now for the embarrassing part....
Had a wheel repair scheduled for one day a couple weeks ago and forgot about my appt. until I was headed out the door to work. Running late (and obviously not thinking clearly), I grabbed one 17" wheel and a jack to throw in the car so I could remove the curb-rashed wheel (20") from the rear of the car to be repaired. In total, drove about 37 miles (a few of those at highway speed, say 65mph) until I got home and put the another 17" wheel on the other side so at least the rear had the same size wheels on. Drove to work and back like that (maybe 15 miles total - no highway) but not until after I started noticing some vibrations especially when accelerating. Now, it is possible (likely even) those vibrations were there before the two 17's and two 20's (front to back) meaning they were (likely) there when it was three 20" and one 17" but I'm just mentioning when I absolutely recall noticing the vibrations. Got home, put all 17" wheels on until 20" wheel fixed.
Wheel fixed, go to pick up, noticed tire bald on repaired wheel while other rear tire had about 5/32 left. Obviously, I had already been driving around on mismatched rears (due to certificate replacement from nail in tire not long after I bought both rears but apparently my left rear wears faster (another issue I realize, but for another time)). Thus, I had been driving around for quite some time with mis-matched rears (estimate 10k miles), then did the stupid thing with the 17" while 20" was being worked on.
Since then, bought new tires, rotated all sorts of different ways with both sets (17" and 20"), two alignments, independent Toyota shop diagnosis., Lexus dealership diag, endless trips to discount for remounting/rebalancing/Hunter road force machine calibrations/checks and all to no avail. Indie Toyota shop and Lexus dealerships refuse to continue diag. without returning vehicle to stock 100% claiming the mods are the cause. That is non-sense. This clearly came up while driving on mismatched sized tires/wheels and is not tire/wheel nor suspension related. Damaged a coilover when lifting the vehicle up so many times is highly unlikely but the only possible way (I can think of) that the suspension would be the cause.
SYMPTOMS: Shudder/vibration through body when accelerating especially between 3 - 5k rpm range. Pull to right when accelerating (wasn't there before and both alignments were within spec - checked twice). Coasts straight, no vibs/shudder when in neutral. No hard shifting going on though. No whining of diffs. All mechanics believe all parts (suspension and driveline) are tight and check out well. No leaks. Tires checked so many times, the guys at Discount know me by name and laugh when I come walking back in. Wheel was not damaged enough to cause any bends and that theory eliminated with stock 17" test.... after test... after test.
All that said, my research now is leading me to differential or transfer case and hopefully not any transmission damage.
QUESTION: If I have damaged the drive line due to mismatched wheel/tire size, for those of you who understand the AWD system on the GS 350, where would you start throwing money at replacing parts? Rear Diff? Front Diff? Transfer case/tranny? Ever heard of this sort of problem with any other Lexus owners before?
I thought about trading it in but even a quick test drive would raise eyebrows. Think I'm going to have to own up to my mistake and figure out best/quickest way to resolve which is why I'm reaching out! Already know it won't be cheap. I'm already at about $1,000 between tires and diag fees.
Sorry about the novel but I truly thank you for any ideas/input as I'm not familiar with the AWD system. Not sure if damage is more likely to be left to right, front to back, in the diff, or in the transfer case, or what?
Haven't done a drain of the diff to see if I have a lot of crap in there. Maybe that should be my next step?
QUESTION: If I have damaged the drive line due to mismatched wheel/tire size, for those of you who understand the AWD system on the GS 350, where would you start throwing money at replacing parts? Rear Diff? Front Diff? Transfer case/tranny? Ever heard of this sort of problem with any other Lexus owners before? (I know the vibration issue is out there, I mean mistmatched wheel/tire size 'actually' causing driveline damages? ....and specific to Lexus)
Just occurred to me: Aren't the front and rear diffs open diffs? If that is the case, and they are not LSD, then wouldn't mismatched tire/wheel size damage most likely be in transfer case? Maybe torque converter or tranny but less likely? Anyone?
Now thinking transfer case drain/fill to check for bits is better place to start than front or rear diff drain/fill.
Last edited by DaGunit; 04-23-18 at 04:00 PM. Reason: clarified question about Lexus' having issues with mistmatched wheel/tire on AWD.
Ant1011 (12-11-20)
I had the same issue you had on my 08 AWD, and had the same wheel setup but on stock suspension.
What cured my issue was completly replacing all the bushings in the car. I would replace 2-4 arms at a time hoping the problem went away it didnt. The pulling to the right, I also had! I think the majority of the issues came from the front lower control arm rear bushing. It looked good, but after I replaced it and got a new alignment the issue went away. Also on the rear I replaced the top chamber arms to an adjustable arm, and had the alignment shop add positive chamber to the rear to help flatten the rear tread.
But def. replace all your suspension bushings at once, and then get it realigned. It will save you a lot of headache, trust me I chewed up a set of 20" tires trying to figure it out.
ibidu1: Good to hear from you again! Long time, no talk. Much appreciate you sharing your experience (as always!). Bummer to chew through $$$$$ tires but better than some of the possibilities I've been fearing with my situation so I'd chalk that up to a lesson well learned (if it were me).
I am down to driveline and suspension at this point so certainly think you could be on to something. The only issue I take with your theory is that this 'change' was realized in 1 day. The day after I swapped those wheels. I def. understand that it could just be a conicidence but kind of doubting it. In fact, I'm thinking, if it is suspension, possibly something I caused when raising/lowering the vehicle (too much stress on some point and whatever was weak/failing just failed right then and there from the stress).
I'd be lying if I didn't have a raised eyebrow at the LCA bushing though. Even though it looks fine, maybe it has failed? In my opinion that theory is better justified when you consider the vibration is under load but I'm reluctant to believe it is suspension related.
What I find myself continuing to think about is "torque". I even say it out loud (when driving by myself) as I'm contemplating all the working pieces taking place as I am experiencing the vibrations.
Regardless, I was thrilled to see a reply and I thank you much for your ideas/experience! I will start looking more down that road to widen my gaze. The independent shop and Lexus both said all suspension elements were checked and seem to be tight and in good working order. Is there anything you can do (besides just replace bushings) to test for problems? All I know is inspect for unusual movement with pry-bar. Were yours showing any signs or just by replacing them was how you got your confirmation?
I am thinking of raising the car up this weekend (on the coilovers) to see if there are any changes due to ride height, suspension angles/geometry as the Lexus Dealership is so convinced is the issue (of which I think is total crap). That is the cheapest/easiest next step.
Then, probably schedule drain/fill of transfer case.
If still an issue, bushings could likely be next.
I do raise the car high enough on one side when changing wheels/tires that I can do both the left front and rear at the same time. I'm wondering what parts that stresses and if that may have caused some sort of damage.
Please feel free to throw out any other ideas/suggestions! Would still really love to know if front/rear diffs are open diffs and if I have my understanding correctly that mismatched wheels/tires would not affect open diff. Any takers?
When you installed the 17s did you get an awd error light pop up? I got that once when one of my 20"s had a flat tire and had to use my spare tire. It freaked me out and I didnt go past 50mph. Putting one off sized tire I assume would be ok because of the differantial, but when you threw on both 17"s I think that may put tension on the driveshaft into the transmission but certain awd transmissions have a awd clutch. When you replace your diff fluid, look for metals or any shiny bits I doubt you will find much. I also doubt you did any internal damage!
As far as the tire wear issue in the rear, I tried pry bar, all my bushings looked and preformed fine under the car. That was the odd issue! It would pull to the right slightly. I tried many shops and I couldnt figure it out. But it was costing money from the tire getting chewed up as I do lots of highway driving. But after replacing all of the bushings minus the front control arms. The issue went away my car doesnt track and doesnt have tire wear issues. Replacing the LCA bushing fixed my issue with the car pulling to the right.
Try putting your ride back to oem, and get the car realigned if you have purchased yearly package for free alignments.
Nope, never seen the awd light before I don’t believe.
I will be attempting to gauge how much debris is in with the fluid for sure. However, I’m not convinced the diffs to be the issue if, as I suspect, the 350 uses open diffs. Instead, I believe (also like you said) that the strain is likely on the driveline into the transmission. The “awd clutch” as you put it, to my understanding, is aka the transfer case.
In other words, if it is open diffs on both axles, the issue wouldn’t be side to side, it would be front to back, likely at the transfer case. One theory I’ve come up might explain how this 30 - 40 miles of driving on different size wheels alone wouldn’t cause this but could have been the icing on the cake. .....and that is the fact one rear was already down to bald (on the driver side only; pass side rear had 5/32 remaining) while the fronts still had 7 - 8/32nd’s. Possibly causing strain for some time and then throw a couple 17” wheels/tire on the back with 20”s on the front and damage ensues relatively instantly (maybe)?
A second/different theory is more in line with what you are saying; suspension related. When paying very close attention last night while driving, I was wrong. There is still a slight pull to the right. It’s also slightly more difficult to turn left than it is right and the return of the wheel after a turn (related to steering memory), is better after turning left than it is turning right. There may also be a slight (very slight) vibration when going straight. Maybe new tires vs old wear patterns is what caused such a quick realization of a suspension problem (maybe)?
Either way, I’m starting to feel better that it is likely one of these two things; hoping for suspension as it will be much much cheaper to repair/replace.
So, still would love to hear confirmation from anyone who might know about open diffs are or are not on front/rear axles.... and.....
A theory as to why, if this is suspension related, the vibration is mainly only noticeable under load? Any guesses on most likely? Ball joint, blown coil over, LCA bushings? I know ibidu1 is thinking bushings. It feels like the car is going relatively straight with a gimp on the front right making me wonder about a ball joint. Just thinking out loud before I begin ordering any parts.
Thanks!
Thanks!
Actually Dagunit traditional 4wd have mechanical transfer cases, awd do not. Awd system would usually give you different power to each wheel. For instance an awd you may get 60% power to the rear wheels and 40% to the front depending on clutch or computer that tracks from speed sensors. If you had a traditional transfer case you for sure would have heard the tires in the back slip as there is no clutch in a transfer case, just gear driven.
My theory for the abnormal tire wear i believe is coming from the bushings.
But for vibrations while under load, that maybe caused from a bent rim, or not having hubcentric shims, abnormal tire wear, driveshaft or cv axle has an imbalance. I suspect its your rims, being bent or warped. Have a job spin them on a balancer and look for any whobbling in the face of the wheel and more important in the rear of the wheel.
Interesting.... Than what is this? Maybe I'm misinformed? Lexus GS 350 Transfer Case
And then HERE you can see where the transfer case actually attaches to the transmission with the rear drive shaft going straight back from the transmission and the jetting out part of the transfer case attaching to the front drive shaft. It is my understanding the clutch pack lives within this unit. I could be wrong of course.
Or maybe I am misunderstanding what you're saying. If you're saying, they don't have mechanical transfer mechanism but they do have one (it's just clutch, not mechanical), than I agree with you. My concern is that I damaged that clutch within by running too long on mismatched tires and then added the different sized wheels, sending it over the top of what it could handle. Probably generating too much heat and damaging parts. That's theory #1 anyway.
An additional mention is that the shudder I feel when on the gas reminds me of what a bad clutch on a motorcycle feels like when taking off from a stop; shudders because torque isn't transferred correctly/smoothly. Additionally, I'm wondering if it isn't currently applying power/torque correctly between front and rear (due to the possible damage) which might be lending to greater torque steer (in the front) causing the pull.
Obviously, I have been thinking about this too much lately. I just wish there was some sort of bread crumb trail so I don't have to waste money guessing. I'm ok with spending money on the car, just don't like the thought of wasting money on the car. I'm sure most of us have been there at some point with at least one of our vehicles though! Cest la vie
Transfer case is part of the AWD transmission and uses ATF from the transmission for lubrication. That's why the AWD car has a bigger transmission fluid pan and filter than RWD cars. That shudder you feel sounds like slipping forward clutches from dirty ATF. You should drop the AWD pan, clean up the magnets and replace the factory AWD filter like I did at 62k.
https://www.clublexus.com/forums/gs-...er-change.html
Good luck with your car.
To be honest, I’m not getting a good feeling of narrowing down the problem. I’m starting to wonder if it might be multiple issues (both suspension and drivetrain) and not feeling any better than say..... 20-25% confident on any one issue which is quickly followed by “$” image in my head.
If I could feel more confident in what the issue is, I’d likely throw the money at it. However, I don’t and, to be honest, prior to this whole issue I was considering getting something new which is looking more and more attractive the more and more time I spend researching this. I’m thinking it’s going to be easier to justify letting it go and putting the money into a new ride.
I have enjoyed this car and would be happy to enjoy it longer but I’ve already got nearly $1,000 into chasing this issue with no real end in sight. Basic logic keeps leading me back to trading it in and putting the money toward something I can be much more certain of. Probably taking off the 20’s and the coil overs next weekend if I can’t narrow down further.
Also, being honest, I feel like the Lexus and independent Toyota/Lexus shops out here are happy to charge you the diag fee and tell you it’s because of your mods and move on to the next (easier) repair. If that is how it is, to me that is another bad sign of this car and keeping it long term. I will not rock a stock GS350 awd.... just won’t happen. I had this thing dropped wishin a week of owning it. I miss my GS400, Lexus has kind of let me down since their itteration of an AWD vehicle. Sorry, starting to rant!
Oh, and an additional mention: I think you are on to something here with your point of dirty ATF causing slipping of forward clutches. That description mates up better than anything else I’ve considered so far when thinking about the problem as it is happening. I don’t see how that could possibly impact “pulling” however which is the logic behind my theory of more than just one issue.
What’s weird is that NONE of this was taking place prior to a quick drive to the wheel shop and back. Crazy, right?!?! No more than 3 weeks ago, I had just convinced myself to forget a new car and stick with this one; no real reason to get rid of it. All because of a light wheel rub at the ATM. **** Chase Bank is the moral of this story! Lol
Update: Just completed the first drain/fill of the ATF about an hour ago. Almost exactly 4 qts on my AWD and had it raised pretty high in front only. Added 4 qts and took her for a spin. Noticeable improvement.
I will be doing a second drain/fill. I agree that you can get more fluid by raising front only so I will do that and add however much comes out plus a bit extra before I raise the back to level it and do the whole fluid level check procedure. Only planning to flush twice for now.
Haven’t paid attention on the short drive to see if this impacted the pull to the right (torque steer related) but I doubt it. I”m guessing that is a secondary issue from the previous 2 attempts to align (just isn’t quite right, prob needs minor tweak).
However, I do anticipate that will resolve 90 - 95% of my vibration under accel issue. I wish it wouldn’t have happened though, now I’ve got my eye on a new ride that I wouldn’t have even been looking at if it weren’t for this. Kind of sold myself now. Time will tell....
Thanks much for the replies and shout out to Server Tech for the suggestion. It was that suggestion that got me linked up with alchemist’s write up on drain/fill the transmission. This is the best the car has felt in a while and only cost me $93 for 9 qts of ATF WS from my local Toyota and $14 for a fluid exchange pump from my local parts store (and a new tool in my arsenal!).
Link to alchemist contribution: HERE Big thanks!
Also wanted to mention that I do believe this problem became so obvious so quickly because of driving on different sized wheels (as well as the tire mismatches prior which weren’t as drastic as the different size wheels). I stated my theory before but to recap, driving on the different tread depth tires caused some strain (read strain = heat / break down). Then the different sized wheels put it over the top by causing excessive heat / break down making the problem more prominent from that point forward. That is my theory anyway. Cheers!
