coilovers this cheap
It's non dampening, your car will ride like crap.
It's basically cheap cheap cheap chinese struts, probably 200 for the whole set, with some coilover springs & sleeves over it.
I wouldn't do it. Anything having to do with the safety of your vehicle driving on the road, you should NOT cheap out on. You can injure not only yourself, but someone else on the road also.
The only adjustments you can make on these are the ride height which is probably whom they're looking to target, users looking to lower their car. Like Gokou said, these look like some reaaally cheap struts, and is probably better to get a reputable aftermarket spring if you were looking to lower your car. I'd imagine some decent coilovers with adjustable dampening would cost an upwards of $1000+
i just was looking for a set of oem struts but when i saw these i thought i would ask you guys ,thanks for the heads up
where can i get a spring strut combo not to expensive
ArmyofOne
09-10-17 11:04 AM
