I fixed a trunk leak in my 2008 lexus gs350
Hello, I was looking to find info on fixing gs trunk leak in here. But since I found the problem myself, I decided to post it here with the picture, so that somebody else might use this info. The spot I marked in the picture is covered by plastic shields which are easy to remove. I ve come to realize that it is ok if there are some space in between those. But the marked spot is where it did leak inside the trunk when there was too much water. I applied all purpose Gorilla sealant there and since then, the trunk is completely dry.
