A/C and heat no blowing out the vents
Hello everyone,
So the other day my a/c just stop working. I switch to heat and nothing. I had all my fuses check and I'm told there good. Any ideas what could be wrong? HELP!!!
Before pointing out that its a faulty blower motor or air inlet servo, why dont you double check the fuses yourself, you mentioned "you were told", check them yourself.
I know that A/C have fuses in three locations, on the Fuse Compartment A, Fuse Compartment B (Both in the engine bay) and in the cabin on the driver side, pull them out and check them not to be blown:
Location of fuses for A/C is as follows:
On the left side of the engine is compartment A (check the fuse #31)
On the right side of the engine is the compartment B, check fuse #7)
On the left side of the cabin (driver side), behind the instrument panel, check fuse #2)
If all that is good then you can start to check the servo and blow motor..
Hope it helps
Hope it helps
skur (09-18-23)
