Amazon Brake Rotors and Pads. Good Deal?
Anyone ever buy their part from Amazon? Just wondering if this is a good deal for front and back rotors plus pads.
anyone ever buy their part from amazon? Just wondering if this is a good deal for front and back rotors plus pads.
https://www.amazon.com/dp/b00ineh2i8...2%3a1248861011
Always buy form dealer
There are high quality aftermarket brands of rotors. EBC is probably the best brand in the non super expensive market. Other than that stick with OEM. Unless you want to guess when your rotors shatter
You don't need to go to the dealer for rotors. Amazon, Ebay or rockauto.com has what you need. Just make sure you get the ones with the corrosion protection around the hubs or they will rust pretty quickly. It won't interfer with performance they just look ugly. I went with the Centric rotors from rockauto front and back for a little over $200.
XJSFan (07-20-17)
You can get good rotors and pads from many sources. Just do your homework and make sure you order the correct parts... In addition, correctly installing them makes all the difference in the world. LOL...
I have Rotora slotted & drilled brake discs and EBC Red stuff. They work perfectly fine to me. The pads however, don't bite as well until I've driven for a while (my mistake for buying something made for hard driving).
Been 3+ years, no noise whatsoever.
Back when I was doing SCCA SOLO II with my FWD car, I looked for affordable drilled rotors. IIRC this was one of the threads I read on the topic http://aurorah.proboards.com/thread/23587
Brakes are one of those "I should spend the money" parts that shortcutting should be avoided.
Just ordered these from amazon. Will update when I have them installed next week..
Centric 125.44138 Front Brake Rotor
Centric 125.44137 Front Brake Rotor
Centric Parts 120.44141 Premium Brake Rotor with E-Coating
Brembo P83072N Front Disc Brake Pad
Brembo P83073N Rear Disc Brake Pad
Thanks
