New 2006 GS 300 Help
Old Feb 14, 2018 | 08:43 AM
  #31
LUX2006's Avatar
LUX2006
Default sea foam sprayed and now trouble codes
i sea foamed my gs the other day and now i’m getting P0305(cylinder 5 misfire)and P0172 (system too rich(bank 1))trouble codes. did i kill my engine? or is this a sea foam known after issue? thanks for any help possible.
Old Feb 14, 2018 | 09:00 AM
  #32
gs350fan's Avatar
gs350fan
Seafoam can dislodge carbon, foul plugs, hold a valve open. I would pull the plug for starters. If the plug looks good take it for an "Italian Tuneup"
Old Feb 14, 2018 | 04:06 PM
  #33
MX73's Avatar
MX73
Is it running normal at the moment? I would clear the code and see if it comes back.
Old Feb 14, 2018 | 04:27 PM
  #34
LUX2006's Avatar
LUX2006
Default Thanks for the help
thank you both for the fast replies. Nope wasn’t running rough. Engine wasn’t shaking violently. Nor was my mpg bad(this bad boy gets good mpg for a large sedan at least for me it does and I don’t drive like a granny. &#128523. Plugs were just replaced a couple of months ago. Strange thing happened today. No auto parts store would clear codes for me. So I ordered my own tool. Since a seafoam rep recommended I clear the codes and drive a while (common issue after using seafoam). After a few stops today the code cleared itself. So I never had an issue. It was all the carbon build up. I had a large cloud following me for a minute. 😋 now my gs is super quiet almost hybrid quiet. 😮 it doesn’t make that hot rod sound anymore when I floor it. However it does move faster more easily now. Btw I did double and triple check that I didn’t mess up wiring or hose connections. I originally thought the check vsc, and traction lights came on cause I did a stand still burnout after the treatment. I went side ways about a foot. 😋 now I just have to replace my faulty door switches and other small plastic parts. 😁 again thanks for all the support from all.
davep84
May 18, 2014 01:03 PM
GSquicksilver
Sep 22, 2004 08:25 PM
SFbaybum
Feb 22, 2004 08:25 AM
