possible engine leak?
I decided to check my engine's oil and do an oil change. I decided to also check out how my zipties were holding up too lol. then i noticed this...
https://cimg3.ibsrv.net/gimg/www.clu...f5ab6a8e62.jpg this is right next to the oil pan https://cimg4.ibsrv.net/gimg/www.clu...b57b9267a3.jpg heres a farther shot... Not sure where the leak is coming from... Any idea guys? |
You can grab a I believe a 10mm and check to see if all the oil pan bolts are snug. Then spray everything down with carb cleaner or degreaser. Then I would check it in a week or so
Originally Posted by ibidu1
(Post 9536014)
Is this an AWD
Originally Posted by SILENTM
(Post 9536541)
Is this an AWD
look around the timing cover area which is on the passenger side of the engine. I usually look up through the oil filter access panel once I remove it. You can see it pretty good from under the car with a flashlight. also check valve cover gaskets. If you had the cam recall, they should have replaced valve cover gaskets with that.
Looks like the front diff case oil seal to me
yes I would degrease it... Clean her up and then check and confirm where it's from
Originally Posted by burny
(Post 9536654)
Originally Posted by Othic
(Post 9538557)
