front passenger door wire cut?
So i looked at my door gap, after looking at it I spotted this... I'm sure this isn't normal but everything seems to be working fine.... I think my memory seating doesn't necessarily work....
https://cimg9.ibsrv.net/gimg/www.clu...1bb741365b.jpg |
Can that be that someone ran side mirror turning signals and then replaced with non turning signal side mirrors? What year? do you have side view mirror turning signals?
Originally Posted by GS350Lexus
(Post 9113413)
I would investigate it further. Weird are not supposed to be cut! If you had the car since new I'm guessing that has to have happened sometime recently. I would have noticed that every time I got in and out if the car since it looks so obvious.
Originally Posted by sha4000
(Post 9113889)
I have the 2007 and I have no wire running through my car like that. Remove the door panel and inspect further see where it leads to. I would not leave it alone, who knows what it is connected to. Also being exposed to water cannot be safe.
(Post 9118489)
Yes check the DIY thread for side view mirror turning signal installation.
Update
Show I decide to take off my front door panel (first time! got kind of nervous because of things could go wrong) So here we go...
https://cimg2.ibsrv.net/gimg/www.clu...8a9a138424.jpg starting from here my wire was cut or broken, you can see it going through the outter rubber sealing of the door... https://cimg4.ibsrv.net/gimg/www.clu...3e13287ebc.jpg The wire is orange,green, and white i followed it through https://cimg5.ibsrv.net/gimg/www.clu...f5fde465f1.jpg here we are, as it ends up merging with these other wires https://cimg6.ibsrv.net/gimg/www.clu...6b9c85edf3.jpg as u can see it all joins and connects to that plug... Now i'm not sure exactly where this plug leads but it's in front of the memory seating.. In the end everything still worked perfectly fine as it was... I'm not entirely sure what it is either... maybe some insight? |
I believe it has something to do with an immobilizer that was installed at one point. There is a company called Xpresskit that makes them and they use those two colored wires to run to the locks for the door.
Originally Posted by Broncosi
(Post 9157981)
