New owner Lexus GS 350 2008
hello guys i am a new owner of the gs 350 2008. Oh man pretty awesome car. I Live in Dominican Rep. Where de have lexus dealers. I am not the first owner because my car were from USA directly and i have some issues about some things...
First of all my Windows will down pressing unlock but when i press lock button it does not do anything... Is that a dealer option on customize this?
The second issue is the auto headlights.... The headlights doesnt turn off if i leave it in AUTO. I have to turn it off manually but understand because the sensor is ok because when im on a tunnel the lights will come on ... Is that a customize option too? Thanks
Btw i came from a 2006 Acura TL hahaha the thing that i miss is hearing kicking VTEC after 4700 rpm but this is a all new level hahaahaha and of course more standard features but anyways this is a beautiful car. Thank you
The windows won't roll up with the remote, only down. Not sure why as it seems to be a desirable feature, but that's the way they designed it and even the 4g is the same way. You have to actually insert the key into the door and hold it in the lock position to roll the windows up from outside of the vehicle.
Have you waited long enough to see if the headlights automatically turn off?
Believe it or not, your GS350 has double the "VTEC" power than your TL. It has a smoother powerband, alongside a more powerful one (240ISH HP TL vs your 306HP GS). This is why you don't hear it, feel it, nor need to .
Seems legit, so I never questioned it.
Try the method above. This isn't a feature last I checked. It was standard.
I tried but no luck :/
Btw i don't see each tire pressure of my car... I was able to do that on my TL. I could see every tire pressure ... But i know lexus have tpms but i dong know where i Can Read my tires
sreenivasr
06-12-15 12:10 PM
