Engine Ticking
Old Apr 8, 2014 | 10:55 AM
NYKnick101's Avatar
NYKnick101
It is a little louder than normal but that ticking is normal engine sounds. I would definitely take it in to get it looked at. My IS sounded like that for a while and I ran some injector cleaner in a full tank of gas and it quieted it down a lot. May be something to consider as well. Clogged injectors can cause them to work harder which can mean louder than usual engine noise. How is your MPG looking? Sounds like the engine runs fine but is it at peak performance
Old Apr 8, 2014 | 11:08 AM
uberEJ's Avatar
uberEJ
you know what... ill try that. what injector cleaner did you use?
thanks for the tip man
Old Apr 14, 2014 | 06:00 AM
NYKnick101's Avatar
NYKnick101
I used seafoam because I have used it in other cars and had good results. I'm sure some other people would have some other injector cleaner suggestions like 3m or some other store brand injector cleaner. Its a cheap fix if that is your issue. Just dont use too much in a short period of time. 1 bottle every 4-6 months is recommended by most
Old Apr 15, 2014 | 04:27 AM
uberEJ's Avatar
uberEJ
ill definitely have to give it a try. it definitely might help.
I went out of town again and then when I got there no ticking. the following morning after a couple friends and I went to eat it was there... before we left and after we got to our destination (about 10 miles)
ptrustfull
Jun 6, 2019 06:45 AM
dsk75
May 22, 2018 11:01 PM
lexisaurus
May 30, 2017 05:29 PM
noh626
May 9, 2015 05:32 PM
new2005GX
GX - 1st Gen (2003-2009)
22
Sep 19, 2013 10:39 PM
