Blown center speaker ML
So it seems like my front center dashboard speaker is blown in my ML system GS and i was wondering if anybody had suggestions for an aftermarket replacement. I called lexus and they want $312 for the center speaker and I figured I can probably find something better and cheaper.
I think the size is 2.5" but not sure if any 2.5" will work and what rewiring if any will need to be done. |
just go aftermarket. the ML system for Lexus isn't the best anyways
Any particular brand/model that you can suggest?
Originally Posted by yoitsdre
(Post 7807394)
I think the size is 2.5" but not sure if any 2.5" will work and what rewiring if any will need to be done. I know I am not answering your question at all, I just figured I would share the information with you since its a substantial savings over your dealer and will be much easier just to replace with OEM. -Joe |
Ouch thats expensive. If you go aftermarket, you should change them all no?
That happened to me last year! I just took it out and continued on, average person could not tell the sound difference. But before I was going to buy an aftermarket one and just pop it in but the sound was fine without it so I didn't.
thanks jamodeo, I will keep in mind sewell as it is a considerable price difference.
benztolex - Didn't know i would have to replace all speakers if I wanted to change 1 of them to aftermarket. Can anyone confirm this? energie8 - so i can just unplug it? I thought no sound would play if any of the speakers was unplugged...? |
The Lexus ML is trash in the 3GS, def change it with another speaker, I think there is a repair kit for it that strengthens the paper cup. I would still get a new one though. +1 on changing them all if you decide to go with an aftermarket one, also I have seen them on Ebay.
Originally Posted by bigblack06
(Post 7807774)
Also, wouldn't it be cheaper to just replace the one speaker with OEM than changing everything to aftermarket? Unless you really dislike the ML system, why change out the entire thing? just my .02 -Joe |
(Post 7807772)
The stock system speakers are all poly, except the tweeters and they are silk domes. The ML system utilizes paper cones in the doors and metal dome tweeters. I don't know if the center channel or small mids in the dash are paper or not because I have not personally seen them. Many audiophiles prefer paper cones as they are the most natural sounding speakers versus othe materials. You can most likely find a speaker that will work with very little effort at Madisound or Parts Express on-line for about $20. The stock center channel on the ML system is 8ohms and 10ohms on the stock system. If I recall correctly, the stock center is approximately 2". The center grill comes off very easily by using a pick to credit card and prying up at the front inbetween the grill and dash.
No way would I spend about $200 on a $10 speaker when I can find something close or better for about $20. |
yoitsdre --- hey does your center speaker rattle? If so , it may not be blown. The glue around the cone might have just some aloose like a lot of ours have and make it sound blown. I used standard paper glue and its been on there for 2 years,no problems.
Originally Posted by jamodeo
(Post 7807850)
I thought that the ML system uses metal cones, that is one of the advantages over the stock paper cone system.
Stock system FTW!!!
(Post 7808396)
I recall when I took it off it was a paper cone, I could be wrong but I think that's what I saw when I took it apart.
-Joe |
