catalytic converters delete help
Old Jan 21, 2013 | 08:25 PM
Charlie088's Avatar
Charlie088
Default catalytic converters delete help
I'm thinking about deleting my cats. I believe our cars come with four. Mainly doing out for a little bit more noise. I already deleted the resonator and is running aftermarket mufflers but I would like a little more noise. I've read a coupe threads staying that if we remove our cats it will throw a cel. I was thinking can I some kinda way use this electriced muffler cut off valves and x pipe it to my mufflers? I can clear the cel come inspection time and still have the factory cats. Or could I get hi flow cats for a more better tone?
Old Jan 21, 2013 | 10:04 PM
designo's Avatar
designo
First of all, is your car a V8 or V6?
If de-cat your V6, you might not like the raspy sound, unlike the V8's.
Also, your car has mufflers as axle-backs. The come the mid pipes which have your secondary cats on them and a resonator. You can de-cat that pipe or replace it with a resonated mid pipe. ( Which is what you have in mind doing )
Your primary cats are attached to your exhaust manifolds.
Your car will not throw a CEL is you decat or replace your mid pipes. I have done it and I have no issues!
Old Jan 22, 2013 | 06:24 AM
passnu2's Avatar
passnu2
I suggest to convert it a true dual exhaust and just get rid of the mid cat but leave the primary ones in place. As for sound are you a V6 model or V8?
Old Jan 22, 2013 | 06:34 AM
Charlie088's Avatar
Charlie088
Thanks guys. Its a v6. Can I replace the mid cats with just pipe?
Old Jan 22, 2013 | 06:45 AM
AustinSBP's Avatar
AustinSBP
u sound like you may have done this to a V8 as well.. im pretty curious about de-catting my V8
Old Jan 22, 2013 | 08:28 AM
designo's Avatar
designo
Do a search on me bro, and check out my signature!
2istype
Mar 6, 2019 04:35 AM
eicca
Performance
15
Sep 2, 2016 09:58 PM
ISFTOMMY
IS F (2008-2014)
16
Jun 27, 2016 08:42 AM
SLMis
Feb 18, 2016 03:21 PM
ROBERTDH
IS F (2008-2014)
Jan 2, 2014 06:44 AM
