Fuel light flashing
Old Nov 15, 2012 | 07:46 PM
GCOP's Avatar
GCOP
CL Folding 100,000
Default Fuel light flashing
So check this, my low fuel light will ramdomly flash, it is a steady pulse, doesn't seem to matter how much fuel I have, or don't have. Never seen this before..any ideas. It doesn't do it all the time, it goes off by itself, usually within a day, no fault codes.
Old Nov 17, 2012 | 08:42 PM
GCOP's Avatar
GCOP
CL Folding 100,000
Nobody????
Old Nov 18, 2012 | 05:16 AM
worker's Avatar
worker
i've never seen or heard of it happen. don't think this is even in the owner manual.
Old Nov 18, 2012 | 04:08 PM
HotShotEng's Avatar
HotShotEng
Fuel sensor may be going bad or could be due to insufficient tightening of the fuel pressure sensor or loosening of the senor nut to the delivery pipe. I know that there was a recall for leaky fuel senor gasket awhile back. Are you noticing or smelling any raw gas. Other than that not sure what it could be.
Old Nov 18, 2012 | 08:44 PM
GCOP's Avatar
GCOP
CL Folding 100,000
No not at all.....everything seems normal, except for the occasional flash....totally ramdom thing. I talked to a Lexus specialty shop, and the local dealer, both said thed never heard of such a thing. The light was actually flashing when I went by the specialty shop....a head scratch and a 'mmm..." was all I got. I would guess if something were starting to loosen, the problem would get worse as time went on IDK
This has to have happened to someone before...as I said, it hasn't effected anything, but not knowing is pissing me of.
Old Nov 18, 2012 | 09:29 PM
worker's Avatar
worker
same number of flash every time?
here's a crazy test, go to a big empty parking lots and drive in circle. do both clock wise and counter. should create an uneven fuel level see if this recreate this flashes.
Old Nov 19, 2012 | 08:15 PM
GCOP's Avatar
GCOP
CL Folding 100,000
Same flash every time, like a ticking clock. I tried the driving in a circle thing...nothing...except for folks looking at me funny...
AlaskaUSA
Jun 9, 2014 09:25 AM
mckdaddy
23
Jun 20, 2012 07:08 PM
carbonlexi
Jul 12, 2011 01:33 PM
stevenss54
Oct 22, 2010 11:41 AM
whlkev
Aug 15, 2008 01:02 PM
