Ordering new wheels..NEED HELP WITH OFFSET!
Hi guys I'm ordering wheels pretty soon and I need help with offsets. The wheels I'm going with are the Leon Hardritts Orden. I don't know which offset to go with. Fenders will be shaved but don't really want to pull. These are the 2 offset I can't decide on.
20x9.5 +26 (2" lip) / 20x10.5 +25 (3" lip) - flush, no poke or 20x9.5 +13 (2.5" lip) / 20x10.5 +13 (3.5" lip) - 1/5" poke will these offset work with just a fender shave? Car is lowered 2" all around. Will go a little lower but Its my daily so I don't want to run crazy camber. Want to get the most out of my tires. |
im pretty sure if you go +13 you'll need to pull. The other 2 are a bit aggressive but should be ok with being shaved. someone can correct me if im wrong
For the first two no need pull just need to shave, depend on how much you want to drop.
was thinking about 1/2"-1" more
Offset gurus I need help! Lol
bump bump!!
you will need a pull for +13. +25 is fine, with a little work (shave, roll). fronts look ok for the +26, work will be needed for the +13.
i'm going to be going with very similar offsets sometime soon (+13), but i have no issue with the work. all depends on what you want to do. |
First one looks good
Sorry to OP for threadjacking but hey offset gurus can u help me on my thread? https://www.clublexus.com/forums/gs-...ml#post7188515
