2007 GS350 AWD 225/40/18 front 255/40/18 Okay?
Old 05-23-11, 11:00 AM
trdsw20
trdsw20's Avatar
Default 2007 GS350 AWD 225/40/18 front 255/40/18 Okay?
Can i use 225/40/18 front and 255/40/18 rear for my 2007 Lexus GS350 all wheel drive 18x8 wheels? People is telling me that i am going to damage the car. Please advise Thanks
Old 05-23-11, 11:30 AM
rominl
exclusive matchup
rominl's Avatar
i don't think that's a good idea at all. that sounds like almost 1" different in diameter from and rear, the awd system will probably give you trouble
Old 05-23-11, 11:35 AM
trdsw20
trdsw20's Avatar
Thanks for the reply, but i see that BMW 335xi has the same set up from the factory
Old 05-23-11, 11:47 AM
IXI187IXI
IXI187IXI's Avatar
BMW ≠ Lexus
Old 05-23-11, 12:05 PM
Lex Luga
Lex Luga's Avatar
I remember hearing BMW awd's are not 50 50 power distribution from front and rear, they are like 60 rear, 40 front so that probably makes a difference with the tires. Does anyone know if Lexus awd is 50 50 power distribution?
Old 05-23-11, 12:10 PM
*Batman*
*Batman*'s Avatar
To have roughly same diameter, you need 225/40/18, 255/35/18
Old 05-23-11, 12:29 PM
designo
designo's Avatar
Agreed!
Old 05-23-11, 12:41 PM
rominl
exclusive matchup
rominl's Avatar
that is bmw, absolutely zero to do with lexus. they are not using the same awd system right? it's all about how the system is programmed to determine slip / distribution. all you need to think just that in your lexus, right now awd system is expect same rotation on all wheels. imagine different diameter, front and rear different rotations, and computer will go nuts
Old 05-23-11, 12:49 PM
*Batman*
*Batman*'s Avatar
Not true. On the base 335xi it is non-staggered 245/45/17, and on the 335xi Sport or M-Sport BMW has what I described earlier: 225/40/18 and 255/35/18. This setup keeps the diameter of front and rear within 0.08".
And on the 550xi they actually use a non-staggered setup even on the M-Sport models. I reckon the F30 xi will also be non-staggered.
Old 05-23-11, 01:39 PM
jtrue28
jtrue28's Avatar
That's almost an inch smaller than spec. You think your AWD has a gap now, wait till you install that setup.
Old 05-23-11, 01:53 PM
*Batman*
*Batman*'s Avatar
Which is why the best setup for this fellow would be stick with his stock tires - 245/45/18
Old 05-23-11, 05:14 PM
mr3gs300
mr3gs300's Avatar
the last thing youre gonna want is to be looking smooth and broken down on the side of the road try to stick as close to stock diameter,its the best way to go
Old 05-23-11, 07:38 PM
msgs350
msgs350's Avatar
i believe stock tire sizs is 245-40/18 all around. If you want the staggered look, yu can try spacers on the rear. i had a 10mm with my stock 18x8 and had no issues. 15mm would work too.
Old 05-23-11, 10:17 PM
vladbph
vladbph's Avatar
GS AWD power distribution is 30/70. it comes with 225/50 R17 all around.
Old 05-23-11, 10:26 PM
rominl
exclusive matchup
rominl's Avatar
if you have 245/40/18, then 285/35/18 rear will work
Quick Reply: 2007 GS350 AWD 225/40/18 front 255/40/18 Okay?
