Anyone converted Non-Navi to OEM Navi successfully?
Old 12-15-10, 09:45 PM
truongsta8
truongsta8's Avatar
Default Anyone converted Non-Navi to OEM Navi successfully?
Has anyone successfully converted a non-navi GS to a Navi GS with all the correct parts? I have an 06 GS w/o navi and i want to get all the necessary parts to turn my car into one with navi and the factory ML dvd player.. anyone attempt this yet?
Edit: Ok so i got the stuff in the mail and as i was going thru it, i was trying to figure out what this piece is and where would it go in the car? It has like 4 switches on it. Anyone have any ideas? Thanks..
Attached Thumbnails Anyone converted Non-Navi to OEM Navi successfully?-100_5416.jpg
Old 12-15-10, 09:57 PM
rominl
exclusive matchup
rominl's Avatar
not that i know off. one pretty expensive project
Old 12-15-10, 10:17 PM
blacksedan
blacksedan's Avatar
http://cgi.ebay.com/ebaymotors/LEXUS...ht_3752wt_2902
Old 12-15-10, 10:48 PM
GS350Lexus
GS350Lexus's Avatar
You can probably get the nav head unit for about $1000, then you will need DVD slot for nav, and wires. Its a huge and expensive mod that a lot of people wouldn't do. I would suggest an ipad or do a search to connect you're ipod through regular screen and you can use nav from it.
Old 12-15-10, 11:10 PM
ekc
ekc's Avatar
That would be easy if all you have to do is switch out your non-nav unit with this. But you're still missing the DVD drive which is in the glove box, and all the wires that connects from the drive to the screen.
If you want the ML DVD changer and nav unit, that's probably impossible since the speaker count is different (10 vs 14).
As others have said, not worth the money and hassle. Might as well spend a couple thousand more and get a GS with factory nav. I'm selling mine.
Old 12-16-10, 04:10 AM
IXI187IXI
IXI187IXI's Avatar
way too much work for a crappy system. to be honest, the lexus navi is not that great. a cheap $200 garmin is better.
Old 12-16-10, 05:32 AM
truongsta8
truongsta8's Avatar
well i just bought this kit so maybe it'll be an easy install... looks like it comes with everything...
http://cgi.ebay.com/ebaymotors/ws/eB...m=280603351920
Old 12-16-10, 05:37 AM
IXI187IXI
IXI187IXI's Avatar
that actually looks pretty good and is pretty cheap let us know how it goes!
Old 12-16-10, 06:37 AM
lkapimp216
lkapimp216's Avatar
There you go look up how to make it all work while in motion while you got it out of the car its a wire harness mod and ground out the parking brake wire
Old 12-16-10, 11:38 AM
blacksedan
blacksedan's Avatar
make a DIY!
Old 12-16-10, 12:07 PM
GS350Lexus
GS350Lexus's Avatar
U got a big project on you're hands, good luck keep us updated.
Old 12-16-10, 04:17 PM
cpcalkins
cpcalkins's Avatar
5th gen nav with 4th gen wiring... very eager to see how this project turns out...
Old 12-16-10, 10:23 PM
truongsta8
truongsta8's Avatar
I really want to do this conversion because i want to be able to play dvds in the car without having to fabricate a custom dash and requiring to relocate the oem screen to the glovebox for climate controls.
i know the ipod connectivity was an option but to play dvd i would require a separate dvd player somewhere else in the car. My big thing was the 6 DVD changer that came with the ML stereo was what really got me into all this.
I will keep u guys posted on this "little" project of mine..
can you please get the a link for this mod? thanks ahead!
Old 12-17-10, 12:10 AM
GS350Lexus
GS350Lexus's Avatar
Here is the link with few options to choose from https://www.clublexus.com/forums/gs-...ds-thread.html Enjoy and don't forget keep us posted!!!!!!!!!
Old 12-17-10, 04:11 AM
lkapimp216
lkapimp216's Avatar
I play DVDs in my car, I have a half din DVD player in the glove box. I have a non nav unit. I purchased a module called NAV tool which plugs into the factory head unit and allows a audio/video input into it. Run a power source and some RCA wires, ground out the yellow parking brake wire and if you have Nav you have to splice your vss wire if your non nav you just cut it and cap it off and you can watch DVDs on your factory screen while in motion. Great for passengers!
Quick Reply: Anyone converted Non-Navi to OEM Navi successfully?
