3GS Steering Assist Options?
I just leased another GS for business use, a 2010 GS 350 RWD. I've been driving my personal 2006 GS 300 AWD for years now and I swear I feel a big difference in the steering feel. My GS 350 is noticably more powerful, but for some reason the GS 300 has a sportier tighter steering feel. As if it has less power assist and more direct feel.
At first I thought I was crazy when I was driving it home, but then I jumped back into my 2006 and I know for sure there is a difference. Is there a different steering option that I am unfamiliar with, or was there a change? My 2006 did have the steering rack recall done years ago, but I didn't notice a change when they did that so it has felt the same since I bought it. Anyone know what the difference is here? |
The only thing i can think of is tires that make it softer,
Originally Posted by GS350Lexus
(Post 5870629)
I think he's referring to tire pressure, which can cause it. I'm with you though, I wish my 07 had better feedback and less power assist but it is what it is. It's not a sports car!
Well 18 weight more then 17, check tire pressure. Also if you got grippy tires it will be harder to steer. Thats really all i can possible think of that could be the difference between the 2. Oh well maybe gs350 weights more because of bigger engine and awd differential in the front which will also make steering stiffer.
Wouldn't the differance between AWD and RWD play a factor in this? With power going to the front wheels, I'd think the steering setup between the 2 cars would be a bit different.
Did you have VGRS on your GS300? VGRS increases assist at lower speeds. Could be that.
Also If you have both AVS and VGRS there is a noticeable difference in steering weight in sport vs normal. |
Originally Posted by batman75
(Post 5871475)
I think its actually that the GS430 and GS460 have the VGRS and the GS300 and 350 have 3.1 turn lock.
here is the site link.http://www.lexus.com/models/GS/detai...fications.html |
Originally Posted by bigblack06
(Post 5872951)
here is the site link.http://www.lexus.com/models/GS/detai...fications.html This link shows the GS300, GS430, and GS450h as having the option. Curiosly, the GS460 is not on this list. Also, let me clarify that I'm only saying that my GS350 doesn't seem to have the option. Don't know about other ones. http://www.lexus.com.bh/technology_e....asp?model=All |
It's strange though. I've driven other cars with this type of technology and this isn't really what I'm experiencing. The steering just feels tighter at all speeds.
if your 06 has vgrs, then it has to be on your sticker because it's an option, i don't think it's standard feature.
and even if your car has the feature, i doubt it's what making your 06 steering "tighter". the whole idea of vgrs is to making steering more responsive at low speed, it doesn't make the steering tighter. i have driven a lot of ls460 and my ls460l had vgrs so i could tell the difference. it could be that when they did the steering rack recall, they tightened up the steering column pretensioner. back in the 2gs days it was a way to get tighter steering with a bit compromise on power steering. if you had the car and did the recall and steering tightened up, changes might not be as obvious compared to now when you jump between the two cars. i know when i put mods on my car, often time i notice difference, but they are much more noticeable when one day i take everything out |
Originally Posted by rominl
(Post 5873143)
Originally Posted by jre002
(Post 5873169)
It's definitely not a VGRS issue. I agree. After I thought about it, the VGRS would not cause the differences I noticed between the two cars.
i don't have much personal experience with the 06 gs300 (or gs430 for that matter) to give a good comparison |
(Post 5873180)
i really tend to wonder if the steering recall had something to do with it.
