Water spots! Lame!
Old Aug 15, 2010 | 01:35 PM
KingTX1981's Avatar
KingTX1981
Default Water spots! Lame!
I was at a buddy's house in the 'burbs, and parked my car in his driveway...well he has a full on automated sprinkler system which got the side of my car. I was there all day and the hot south TX sun dried it off, leaving some nice little water marks that I discovered this morning. To top it off - I'm driving obsidian
Anyways - took it for a wash this morning, to no prevail. I did some research, and read about people successfully using vinegar. Wanted to touch base with the "experts" before making any moves
Old Aug 15, 2010 | 01:38 PM
vuiskool's Avatar
vuiskool
on my dark car I wash with gold wash with a sponge and then another rougher sponge over it again and dry it off with an absorber. Seems to do the trick. if not try clay+wax.
Old Aug 15, 2010 | 02:02 PM
BinaryJay's Avatar
BinaryJay
Next time use a sealant on your paint (like Duragloss or Klasse), it'll prevent hard water etching.
Old Aug 15, 2010 | 02:07 PM
TWong350's Avatar
TWong350
CL Folding 10,000
A clay bar likely remove them.
Old Aug 15, 2010 | 04:55 PM
SNiiP3R's Avatar
SNiiP3R
Shampoo wash -> clay bar -> wash -> wax or polish or sealent = clean and shiny
The above suggestion is for people with tons of free time on their hands. The easier way is to get either Scratch X or Sonus SFX Scratch Removal. Apply after you wash the car.
Old Aug 15, 2010 | 05:21 PM
Valley101's Avatar
Valley101
Default Water Spots
Had a similar problem on Deep Sea Mica. I used 3M Finesse It II. Use a microfiber and do by hand. I applied in a straight line, not a circular motion. Test a small area using light pressure and then adjust up the pressure a little more, if need be. Using a machine might cut too much into your clear coat if you are not a professional. I buffed out and applied a sealer made by Meguiar's that I use on my other vehicle with good results. I have used Finesse It for years on other vehicle for blemishes and other problems. If applied correctly it will get the job done without doing any damage. I first got it from a friend who owns a body shop. Good Luck!.
Old Aug 15, 2010 | 05:55 PM
I8ABMR's Avatar
I8ABMR
clay bar and a little wax will fix it for you. The clay bar is magic
Old Aug 15, 2010 | 06:05 PM
jtrue28's Avatar
jtrue28
is it necessary to re-wash after claying? if you're using detailing spray as the lube, can't you just wipe that down with a towel and be fine? seems like washing the car again in the sun just starts the process all over again.
lexusbexus
NX - 1st Gen (2015-2021)
19
Sep 1, 2022 01:46 AM
itsivan
Aug 3, 2013 09:45 AM
horent135
Automotive Care & Detailing
Jul 19, 2012 09:17 PM
MrG4Life
Aug 25, 2009 12:53 PM
