need wheel help with PICS
Old Jul 29, 2010 | 06:41 PM
lexasgs400's Avatar
lexasgs400
Default need wheel help with PICS
I just purchased the car with 20" EXE Konvex wheels
20X9 Front with a 245/30/20
20X10 Rear with a 265/30/20
I am unsure of the offset but it sits like a 4x4 because of the 30 series tires
so I need to lower it or change the tires
The problem is the previous owner said Discount originally installed 275/30 in the rear and 245/35 in the front (which would have been perfect) but it rubbed so Discount tire changed them out instead of ordering the proper offset.
How should I correct this?
What is the correct offset for a 20x10 rear and a 20x9 front, I would like to use a very mild lowering spring but dont want a tire rub.
Attached Thumbnails need wheel help with PICS-dsc_6680.jpg   need wheel help with PICS-dsc_6686.jpg   need wheel help with PICS-dsc_6687.jpg
Old Jul 29, 2010 | 07:11 PM
Chancellor's Avatar
Chancellor
Your offsets aren't that low so you will be good with a mild drop. My next tires will be a 255/30/20 on a 10 so the 265 that you are running is fine.
Old Jul 30, 2010 | 11:08 PM
lexasgs400's Avatar
lexasgs400
Default offsets
I just found out my offsets
front 35
rear 37
Can I lower with these
Old Jul 31, 2010 | 06:40 PM
Mike450h's Avatar
Mike450h
front 35
rear 37
Should be a non-issue with those offsets.
truenoboy
Aug 29, 2016 08:51 PM
Benjamin T
Wheels, Tires & Brakes Forum
42
Dec 18, 2013 04:01 PM
thomastan
Mar 24, 2009 05:46 PM
cmc07e
Apr 7, 2007 10:16 PM
02Ku
Apr 6, 2006 08:42 AM
