Do 225 45 18 Tires Fit on GS 350 18" Wheels
Anyone?
Debating to get the
225 45 18
or
235 45 18
Want some more cushion in the ride... Which one is better/cheaper?
Debating to get the
225 45 18
or
235 45 18
Hello there
Both will fit fine, 235 45 will give more cushion than the OEM 245 40s, 225 45 is same sidewall height as oem 245 40...
use this calculator
http://www.1010tires.com/TireSizeCalculator.asp
use this calculator
I put 245-45-18 on my...... It feels and ride perfect(it touches the inside fender a little when turned the whole way but no major problematic concern ).... However, 225-45-18 is good too but it may look a bit thin and of course will save you a lot of gas.... 225 is thinner than 245 and therefore it has less fiction on the road. You will the like the ride.
Dh
lexus actually recommends 225/40/19 on their 19" wheels, so 225/45/18 would definitely be fine.
