List of Voice Commands for the GS350
Old 12-13-06, 08:28 PM
AZHenry
AZHenry's Avatar
Question List of Voice Commands for the GS350
Anyone know where I can get a printed list of voice commands for a GS350? I know I can go to help and they list them there but I would like a paper copy to refer to (and memorize).
Thanks for any help you can give me!!
AZHenry
Old 12-15-06, 02:40 AM
jaxgs350
jaxgs350's Avatar
Thanks to sonartech for this list, posted it the Tips sticky earlier this year:
65 degrees, 66 degrees, 67 degrees, 68 degrees, 69 degrees, 70 degrees, 71 degrees, 72 degrees, 73 degrees, 74 degrees, 75 degrees, 76 degrees, 77 degrees, 78 degrees, 79 degrees, 80 degrees, 81 degrees, 82 degrees, 83 degrees, 84 degrees, 85 degrees, AM radio, Add to destination, Address, Arrow guidance, Audio, Automatic air conditioning, Back, CD changer, Cancel, Cassette, Change city, Change house number, Change map direction, Change state, Change street, Change to heading up, Change to north up, Change to turn list guide, Command help, Command list, Compass mode, Cooler, Current position, DVD, DVD changer, Delete all destinations, Delete final destination, Delete next destination, Destination, Destination 1, Destination 2, Destination 3, Destination 4, Destination 5, Detour, Detour entire route, Detour route, Dial by Name, Dial by Number, Disc down, Disc up, Dual map, Enter destination, Entire route, Entire route map, FM radio, FM1, FM2, Fast forward, Fifth destination map, Final destination map, First destination map, Fourth destination map, Freeway guidance, Go home, Go to 1, Go to 2, Go to 3, Go to 4, Go to 5, Go to destination 1, Go to destination 2, Go to destination 3, Go to destination 4, Go to destination 5, Go to preset destination 1, Go to preset destination 2, Go to preset destination 3, Go to preset destination 4, Go to preset destination 5, Go to previous destination, Go to previous start point, Go to previous starting point, Go to quick access 1, Go to quick access 2, Go to quick access 3, Go to quick access 4, Go to quick access 5, Go to quick access No. 1, Go to quick access No. 2, Go to quick access No. 3, Go to quick access No. 4, Go to quick access No. 5, Heading up, Help, Hide all icons, Home, Intersection guidance, Lane guidance, Louder, Lower temperature, Map, Map direction, Map screen, Mark, Mark point, Mark this point, Navigation, Next Candidate, Next destination map, Next disc, Next track, North up, POI off, Play, Previous destination, Previous disc, Previous start point, Previous starting point, Previous track, Program, Quick, Quick 1, Quick 2, Quick 2 route, Quick access 1, Quick access 2, Quick access 3, Quick access 4, Quick access 5, Quick access No. 1, Quick access No. 2, Quick access No. 3, Quick access No. 4, Quick access No. 5, Quick route, Quickest, Quickest route, Radio, Raise temperature, Repeat, Repeat guidance, Repeat voice, Replace destination, Resume guidance, Reverse, Rewind, Right map direction, Right map heading up, Right map north up, Right map zoom in, Right map zoom out, Route overview, SAT, SAT1, SAT2, SAT3, Satellite radio, Satellite radio1, Satellite radio2, Satellite radio3, Second destination map, Seek down, Seek up, Set as destination, Set destination, Short, Short route, Shortest, Shortest route, Show arrow guidance, Show compass mode, Show dual map, Show fifth destination, Show final destination, Show first destination, Show fourth destination, Show freeway guidance, Show intersection guidance, Show lane guidance, Show list, Show map, Show next destination, Show second destination, Show single map, Show third destination, Show turn by turn guidance, Show turn list guidance, Single map, Skip backward, Softer, Start guidance, Stop guidance, Suspend guidance, Tape, Temperature 65 degrees, Temperature 66 degrees, Temperature 67 degrees, Temperature 68 degrees, Temperature 69 degrees, Temperature 70 degrees, Temperature 71 degrees, Temperature 72 degrees, Temperature 73 degrees, Temperature 74 degrees, Temperature 75 degrees, Temperature 76 degrees, Temperature 77 degrees, Temperature 78 degrees, Temperature 79 degrees, Temperature 80 degrees, Temperature 81 degrees, Temperature 82 degrees, Temperature 83 degrees, Temperature 84 degrees, Temperature 85 degrees, Third destination map, Track down, Track up, Turn by turn guidance, Turn list guidance, Turn list guide, Type down, Type up, Voice, Warmer, Yes, Zoom in, Zoom in right map, Zoom out, Zoom out right map.
Old 12-15-06, 08:25 AM
SGT
SGT's Avatar
http://www.vfaq.net/docs/Prius_NAV_Voice_commands.html
Old 12-15-06, 08:55 AM
starstreak
starstreak's Avatar
Are you serious? I NEED to findout how to get voice commands to work. If this is another one of those "you need navigation" deals I am gonna be so ticked! Why the heck would I need Navigation to tell my a/c to goto 76deg?
Wait...I know the Prius, could do all that. Are you sure the GS series will to?
Old 12-15-06, 09:00 AM
SGT
SGT's Avatar
Rest assured, they share the same commands.
Old 12-16-06, 08:51 AM
EXP_Cougar
EXP_Cougar's Avatar
Default NAV commands in PDF
Took the liberty of taking the NAV commands posted here from the Prius link and placing it into an Adobe PDF format. Removed Prius references to make it more generic.
File Type: pdf
Old 04-07-17, 03:41 PM
Vooduguru
Vooduguru's Avatar
Is there a way to retrain the system? Or reset it? Any voice command I do understands different commands
laurenz3
NX - 1st Gen (2015-2021)
13
10-21-21 08:42 AM
tedhw
02-12-18 05:16 AM
BB989898
ES - 6th Gen (2013-2018)
02-22-14 09:29 AM
SkyIS
01-04-08 02:04 PM
cyboriax
RX - 1st Gen (1999-2003)
11-16-03 06:51 PM
Quick Reply: List of Voice Commands for the GS350
