ClubLexus - Lexus Forum Discussion (https://www.clublexus.com/forums/)
-   GS - 3rd Gen (2006-2011) (https://www.clublexus.com/forums/gs-3rd-gen-2006-2011-153/)
-   -   450h won't pass smog due to code U0100 & U0293 (https://www.clublexus.com/forums/gs-3rd-gen-2006-2011/1031075-450h-wont-pass-smog-due-to-code-u0100-and-u0293.html)
Lexman450h Oct 28, 2024 06:11 PM
Help! My car is getting these 2 codes.
U0100 Lost Communication with ECM/PCM "A"
U0293 Lost Communication with hybrid Power train Module
Car drives fine, starts fine, no emissions codes,
Hybrid battery was inspected and is working fine all cells are in good shape.
also VSC, Track off, light on along with check eng light
Lwerewolf Oct 29, 2024 03:09 PM
Clear the codes and see if this persists? Those aren't monitor codes and it sounds extremely weird that the car's running just fine with these (they're codes for CAN issues). Have you checked the regular 12v battery just in case?
Lexman450h Oct 29, 2024 04:08 PM
Quote:
I delete the codes, and they come back , they usually come back on a start up but not all the time, yes the 12v battery is good and strong.checked all fuses and connectors all good.
I want to take a risk and install a new ECM? Any opinions??
Kendoo39 Oct 30, 2024 08:03 AM
Possibly a bad ground location causingintermittentlost connection. Try going through and cleaning the one battery to car and the ground location you can locate behind the kick panels and any others you can locate.
arm123 Jan 1, 2026 10:25 AM
Did you ever end up finding a fix? im getting the same u0293 error code on my 2016 es300h
Lexman450h Feb 12, 2026 05:33 PM
where you able to fix this issue im having the same issue
Lexman450h Apr 9, 2026 03:40 PM
It was the 12v Battery
It ended up being the 12v Battery, I learned that even if the battery is 1 volt low, it will give soo many issues
