2008 GS350 awd bump steer
Old Oct 17, 2023 | 12:02 PM
reoo9592's Avatar
reoo9592
10th Gear
Cool 2008 GS350 awd bump steer
Hello again..
I have 2008 Lexus GS350 AWD which i recently bought. I have bump steer issue where the wheel steering turns to the right when i hit an uneven roads.
Would you tell me how to fix this issue?
Where to fix it?
Is there any mechanic you recommend in Texas, preferably Houston?
Old Oct 17, 2023 | 02:35 PM
BigButtGS's Avatar
BigButtGS
Originally Posted by reoo9592
Hello again..
Where to fix it?
Sounds like a suspension problem. I would reccomend you have your mechanic not only look at your suspension, but also have a good look at the rack and pinion.
Old Oct 20, 2023 | 06:05 AM
ibidu1's Avatar
ibidu1
Most likely the front lower control arm bushings. Its the big round bushing that holds the lower control arm. Thats a common issue that causes bump steer. Usually it doesnt look bad, because its a big chunk of rubber. But when you install the new one makes a difference
djyoshi626
Jul 27, 2020 08:35 PM
Hugh9591
Jun 15, 2019 07:32 AM
chanho083
May 20, 2011 01:48 PM
lexusis305
14
Jan 3, 2011 08:14 AM
HenryHYee
Apr 14, 2008 06:33 AM
