Play in steering wheel.
Old Dec 2, 2022 | 08:55 AM
2jzeezus's Avatar
2jzeezus
6th Gear
Default Play in steering wheel.
I own a 2000 Gs300 that ive had for 6 months, and since ive bought it its had lots of play in the steering wheel. At first i could tolerate it but was still extremely dangerous. Its gotten worse overtime and im finally getting around to fixing it. I decided to start with power steering rack bushings which i am about to install in a few minutes, im mainly looking for any other clues as to what it would be if that is not the issue. Thank you!
Old Dec 2, 2022 | 10:30 AM
DMPesso's Avatar
DMPesso
If you’re able to do that without the wheels moving that’s pretty bad. A bad alignment can cause loose steering with play but would be more noticeable when driving, not parked. I’d start with the rack bushings and tie rods. Since the tie rods are basically connecting the rack to the wheels if they are really bad and there’s no grease left in them it would cause loose steering like you have. I would say ball joints and control arms too but those aren’t known to cause loose steering when parked, they would be noticeable when driving though. Get your rack bushings and tie rods done with a good alignment to start.
Old Dec 2, 2022 | 10:35 AM
DMPesso's Avatar
DMPesso
I just realized I have a brand new set of moog tie rods purchased from rock auto a few weeks ago. I thought I was going to need them to fix my alignment issue but I didn’t. I was keeping them as backup since it doesn’t make sense to lose money sending them back since they’re so cheap. If you want to buy them let me know. Brand new with receipt from rock auto. Inner and outer.
Old Dec 2, 2022 | 11:14 AM
2jzeezus's Avatar
2jzeezus
6th Gear
That helps alot, I havent had the chance to do the bushings yet but i do have them with me, if it does not fix the issue i may take you up on those tie rods. Will keep you posted ! 👍
Old Dec 2, 2022 | 11:47 AM
DMPesso's Avatar
DMPesso
i would imagine your bushings would have to be really shot to cause that much play. Changing mine helped a lot but I’d be surprised if that’s your only issue with that much play. Look at mine before and after. You can see how flat the old ones were which causes the play
Old Dec 2, 2022 | 12:40 PM
captainva's Avatar
captainva
Yeah I put in poly bushings and they didn't do much. 100% you have bad tie rods or something else extremely loose. That sounds dangerous
Old Dec 3, 2022 | 10:07 AM
2jzeezus's Avatar
2jzeezus
6th Gear
Definitely tie rods. my brother hit a deer yesterday so i didnt get to take a look but i just jacked the car up and had my lady wiggle the wheel side to side. tie rod end moves like crazy on both sides, steering rack doesnt move much but has a little shake.
Old Dec 3, 2022 | 10:15 AM
2jzeezus's Avatar
2jzeezus
6th Gear
these are my tie rods
Old Dec 3, 2022 | 10:16 AM
2jzeezus's Avatar
2jzeezus
6th Gear
video didnt post last time
File Type: mov
Old Dec 3, 2022 | 11:25 AM
DMPesso's Avatar
DMPesso
I knew it had to be the tie rods! When they start clicking is when you want to change them right away
Brahms
Jan 8, 2016 09:36 PM
DMPesso
Jun 18, 2014 01:19 AM
BoostAddct
Oct 28, 2011 09:29 PM
ThomasGS4
Suspension and Brakes
22
Jul 3, 2011 01:56 PM
mk4r34
Mar 22, 2010 09:36 PM
