Heated Seats fix
Old Dec 8, 2021 | 02:55 PM
sganesh00's Avatar
sganesh00
Default Heated Seats fix
I took delivery of my new to me 2GS3 back in late August (in TX) and one of the things I realized was that my heated seats were inop. The light doesn't even turn on. Checked fuses and it's all good down there.
I'm going to take it to my indy mechanic soon but I wanted to ask if there are any other things I should check that may make the debugging process easier. I'm a native Texan so naturally anything under 70F means I need to layer up
Thanks!
Old Dec 20, 2021 | 07:57 AM
dwoods801's Avatar
dwoods801
Neither seat works and neither switch lights up? They should light up even if the elements are defective. So I would totally think it's an issue you'll be able to pinpoint with minimal effort. Did you check all 3 fuse boxes, and check for any blown or missing fuses. They should be on a dedicated circuit so nothing else would be inoperable if the fuse for them blew. Also check to see if the wire harness under each seat is plugged in and there isn't any obvious issues with the wiring or plugs. If everything looks good then pull the center console trim up, so you can examine the switches. Check and make sure the switches are also plugged in. If that all looks good then it's time for your multi meter or the Indy Tech. Good luck
Old Dec 21, 2021 | 06:56 AM
QLex300's Avatar
QLex300
Thanks!
Hi
did you find the issue?
Thanks
sfgsdfg999
SC400 / 300 Classifieds
Apr 28, 2017 04:48 AM
acejacks00
Sep 22, 2013 09:48 AM
MrBrock
Aug 6, 2012 07:10 PM
WickedLex
GS - 1st Gen (1993-1997)
Jul 10, 2008 12:10 PM
