Replace dash warning lights
Old Jun 11, 2021 | 06:52 PM
kr777's Avatar
kr777
Default Replace dash warning lights
How would I replace the dashboard warning lights? My ABS/VSC lights aren’t working and I haven’t found anywhere online about replacing these lights.
Also what kind of lights should I buy to replace them, do they need to be OEM?
P.S this isn’t about the backlight on the dashboard, its the warning lights like ECT PWR, cruise control, seatbelt etc.
Old Jun 11, 2021 | 10:04 PM
BlazeViper's Avatar
BlazeViper
They'll probably be LEDs, so you'll have to pull the cluster out, take it apart, solder out the old and solder in the new!
Old Jun 12, 2021 | 06:15 PM
dwoods801's Avatar
dwoods801
It’s pretty straight forward, pull the cluster out and then you’ll find them all lined up, I replaced mine with 3mm LED’s. You’ll find a post with instructions for removing the cluster in the “how to” section.
Old Jul 2, 2021 | 01:57 AM
kr777's Avatar
kr777
Okay, just did this.
Looks like the VSC off, VSC and ABS light were deliberately removed, probably because 2 weeks after I bought the car the brake master cyl died and the fuel pump died on the first week.
I didn’t know what exact new light to buy so I just switched the rear warning light to the VSC off as thats more useful.
For anyone wanting to do this:
Its a very annoying job to do, some of the screws are very difficult to remove and a lot fell into the abyss
Also to remove the lights, its twist and pull not pinch (some youtube tutorial said pinch)
would have been a 20 minute job, but the fuel guage flipped when I took it off making it a 2 hour job as I had to open it completely and flip it over.
Klauss
RX - 1st Gen (1999-2003)
May 7, 2021 11:19 PM
njmurvin
Feb 4, 2009 12:45 PM
MuGGzyx
Lighting
13
Apr 7, 2008 04:18 PM
99LS400BLK
Feb 8, 2008 01:31 AM
siniquezu
Sep 8, 2002 03:02 AM
