Plugging evap lines?
Old Feb 22, 2020 | 06:03 PM
Docretier's Avatar
Docretier
Default Plugging evap lines?
I have a 2001 GS430 with p0440, p0441, and p0446 codes, all relating to the evaporative emissions. My concern is if I have a leak or a solenoid stuck open, that would be a vacuum leak. How would plugging the evap line affect engine performance/MPG/anything else. I live in Florida and they don't do emissions checks so it's not really a concern for me.
Old Apr 20, 2020 | 01:39 AM
RA40's Avatar
RA40
Super Moderator
Better exposure for this in the 2-GS section. Moving
Old Apr 20, 2020 | 06:48 AM
TrueGS300's Avatar
TrueGS300
EVAP is only an emissions concern unless the purge valve is stuck open and causing a lean running condition. But other than that, it doesn't effect run-ability. To delete the system, you just remove the vacuum line from the purge valve and cap it off at the intake. Then it cannot have an effect on the engine anymore. However you should consider if you are fine with contributing to pollution. If you don't care, fine, if so, get it fixed. Usually just start by checking your gas cap. Does it close tight? Is the seal still there? Not totally flat? Not cracked?
Miintt
Nov 25, 2019 09:01 AM
johnsilly
Jul 21, 2014 03:36 PM
Sheridanrd
Mar 21, 2011 04:55 PM
naughty77
Jul 5, 2008 09:59 PM
alkattan
Nov 17, 2005 11:42 AM
