1998 GS300 split manifold (headers) vs. 2000 GS300 manifold
NEED ADVICE!! 1998 GS300 split manifold (headers) vs. 2000 GS300 manifold
I have a 2000 GS300 i am building and a 1998 GS300 complete car for parts. I noticed that the 2000 has an exhaust manifold that is more like a standard manifold, and the 1998 has a split manifold that more resembles a header. Which is better performance and sound wise?
The difference is negligible. I've had both. My 98 had the longer primary looking ones. Had to replace with any used one I could find to pass smog and ended up with the manifold looking one. No difference in any way that can be felt or heard. But in theory the longer separate primaries should be better.
I have a 99 gs300 and looking for the complete exhaust manifolds/catalytics, because of check engine codes. It says i only can use 98-99, but is it possible to use the 2000-up assembly with some modifications? Whats the difference between the two?
Any info would be appreciate it.
Thanks
Thanks
Thanks
Thanks
Another option is you can run a o2 spacer after the cat that costs around $10 to keep catalytic codes away. I run 2 on mine since I bought some IS300 headers and run a straight pipe exhaust. I do not have any engine lights or issues but the only downside to those spacers is if your emissions place does visual inspections, you will fail with those installed if they see them.
Thanks
Thanks
Nubian
03-26-11 01:05 PM
