What's a good transmission cooler
For 2000 Lexus gs300 |
Originally Posted by Enforcer84
(Post 10437878)
For 2000 Lexus gs300 I think all cooler are the same, just depend on where you mount them. |
The built-in one in the radiator does a great job. Are you running a high HP Lexus, race it a lot or have a fully built automatic transmission?
B&M make great products, but expensive. They really all are about the same and serve the same purpose. They are all universal fit and usually get tied to the condenser by plastic ties. For me it depends on the car what one I go with. For my built Vette, it got a B&M with its own fan (still in series with the radiator cooler). For my old 84 Trans-am after it finally needed a trans rebuild at 30 years old, I picked up a cheap Flex-a-light brand one and ran it in series with the radiator liquid cooler. What I do know is that you always retain the radiator cooler as liquid cooling is much more efficient than air. Then you run your added cooler in series after the radiator cooler and then the fluid goes back to the trans. There is plenty of room on these cars to mount basically any cooler you want.
The B&M is less than $100... That’s expensive? I mean, if you’re comparing it to $80 low grade steel headers I guess so. Also, the B&M is a stacked plate, which is a better design than cheap tube and fin coolers usually found at crappy parts stores, so actually they’re not all the same?:egads: If you want one of those, you might as well just snag it off a truck in the junkyard since b&m is too expensive and all... |
Originally Posted by Revive
(Post 10440539)
The B&M is less than $100... That’s expensive? I mean, if you’re comparing it to $80 low grade steel headers I guess so. Also, the B&M is a stacked plate, which is a better design than cheap tube and fin coolers usually found at crappy parts stores, so actually they’re not all the same?:egads: If you want one of those, you might as well just snag it off a truck in the junkyard since b&m is too expensive and all... Also, researching your B&M part number... your model of cooler at its size and dimensions is meant for heavy duty trucks, for towing, and motor-homes. Way overkill for a sedan, but whatever you want for your car :thumbup: We wont go into why "too cool" is a bad thing or why they put thermostats in transmission systems these days so that the fluid stays warm enough to actually pass through the valve body and through solenoids at the proper viscosity. Bigger is always better :nono: |
Considering the GS already has a transmission cooler that's adequate for a stock vehicle, it's safe to assume they are looking for extra cooling
Originally Posted by TrueGS300
(Post 10440643)
What are you slapping your head for?
Can you tell us more about your sweet vette? :eek2: |
OP, there are plenty of good options out there. The B&M mentioned is a quality item and they've got several decently priced models.
My old one was a Permacool and it worked fine. Search on the forum isn't working right now so can't link you, but plenty of past threads on this topic once it comes back up. Here's one I got with google showing my old Perma-cool setup, just a basic tube and fin type https://www.clublexus.com/forums/per...-cooler-2.html |
