intermediate steering shaft
so i went to ask if they could weld my muffler and came with this list , the important one was i think the ball joints , but after they checked the car they told me the intermediate steering shaft doesn't work because the steering wheel doesnt go back smoothly to the center when i am turning , not sure because mine is a SportDesign or the steering shaft doesn't actually works ,
so with the parts list i see the moogs ball joint from rockauto is for $35 is it worth it or there is a better brand ?
the intermediate shaft is making creaking noise and doesn't go back to the center when i turn , should i change it ? and is there a brand someone used ?
I would get a second opinion on the steering shaft. I think its highly unlikely that anything in the intermediate shaft of the steering went bad and it seems like a BS reason to sell you something. Unless you have a lot of play in your steering I would ask a mechanic you trust before shelling that kind of money to fix nothing
shaheedGS (12-05-18)
i havent touched the suspention yet , i have the drivers side creaking noise but I wasn’t sure if it was the ball joint or the struts , i was going to change the struts with some coilovers but I remember you telling before that I should look for some good brands , the steering fluid is the same normal level, nothing changed. Not sure where to start
I can't tell you if your mechanic is being honest about the part needing to be replaced, but I can tell you that $340.19 is full MSRP for that part and you can definitely get it for at least 20% less from a Lexus parts dealer online.
https://www.mylparts.com/oem-parts/l...ft-4526030080/
Personally, I wouldn't make assumptions about why the steering doesn't return to center until an alignment has been done, but we can't diagnose it from here. I would advise to start with the ball joint replacement and alignment, and see if the problem persists before spending $300 on a part.
As an aside- 2.5hrs for an inspection, damn that must be one thorough inspection.
Definitely do the ball joints. I would just do both sides honestly, especially if you're thinking about lowering the car and it has high mileage. I found some OEM LBJs on ebay for a pretty good price. More expensive than Moog, but worth it for me personally.
I would also get a second opinion on the steering before you do anything.
sdls
22
05-17-18 09:36 PM
