Replace Hood Latch Cable
I know this is common. It’s my commuter car so I’ve just been tugging on it to release but it’s time to finally replace the cable. Does anybody have a write up or video on replacing the cable? It seems simple but with the firewall just want to make sure I’m not getting myself into a headache. Thanks |
In the future go on google and type in "site:www.clublexus.com" then type in your search terms. The search in the site is terrible but you can find anything using google. This is the first result:
https://www.clublexus.com/forums/gs-...placement.html I followed this a while ago and the biggest pain is feeding the cable through the firewall but the rest is easy. I used an old coat hanger that I attached the cable to so I could get it through the firewall. You will need 2 people to do this part. Also take off your grille before you close the hood for the first time. I didn't have an issue but as others have said, if you do its a lot easier to open the hood when the grille isn't blocking the latch. |
Awesome thanks a lot bud |
