99 headlight restoration or replacement
Old Apr 15, 2018 | 10:00 AM
kameleon25's Avatar
kameleon25
Default 99 headlight restoration or replacement
My 99 GS400 has the factory HID with auto level. I have polished the lights every 6 months (2 stage wet sand, 2 stage polish, and uv protectant at the end). My issue is the INSIDE is foggy/cracked. I'm looking into options to fix this. I'm guessing to keep my factory HID I'll need the factory housings. Where is the best place to buy these without spending an arm and a leg? I can't stand foggy lights because it's a safety problem and makes the car look old.
Old Apr 15, 2018 | 11:04 AM
kevin3344's Avatar
kevin3344
I've had the same issue since I hit a deer and my insurance replaced my passenger side headlight. Of course that one is brand new (clear) and my drivers side is original to the car. Of course, no amount of refinishing will get it to look new so I've been looking at two options. One is a brand new headlight to the tune of $599 or so which is probably out. Second is a "close to new" one on eBay for around $200. Which while it may have some imperfections will get me closer to the new one. So far I've been getting by with polishing/sanding my current one and it's been holding up. However, as time goes by I will probably look at replacing it with a very good used example.
Old Apr 16, 2018 | 07:27 AM
captainva's Avatar
captainva
I don't know what you could do about the inside but when you polish the outside next time, clear coat the lens with UV resistant clear after you polish it and it will take a lot longer to fade again
Old Apr 16, 2018 | 10:49 AM
lyonkster's Avatar
lyonkster
I was able to find new HID assemblies for about $250. They are the green tint versions, not sure if they'd match your year. But if you get both, it wouldn't matter .
Old Apr 16, 2018 | 08:19 PM
DundukovEM's Avatar
DundukovEM
Is this price for pair or one side?
Old Apr 17, 2018 | 11:52 PM
silverbul's Avatar
silverbul
Pm me if anyone interested. I have a good set of oem hid headlights in my basement I'm trying to get rid of. Resealed for permanent protection against fading or yellowing.
Old Apr 18, 2018 | 08:54 AM
lyonkster's Avatar
lyonkster
The ones I know about are <$250 each, still way less than the $599 each that were mentioned above.
Old Apr 18, 2018 | 08:11 PM
kameleon25's Avatar
kameleon25
Green tint? Pics?
Old Apr 19, 2018 | 06:31 AM
lyonkster's Avatar
lyonkster
Originally Posted by kameleon25
Green tint? Pics?
Green tint came on '01+ model years.
Driver side: 81170-3A730:
https://www.ebay.com/itm/GENUINE-LEX...9TiPoQ&vxp=mtr
Passenger side: 81130-3A610:
https://www.ebay.com/itm/GENUINE-LEX...dTWXDi&vxp=mtr
__________________
Old Apr 19, 2018 | 09:00 AM
kameleon25's Avatar
kameleon25
__________________
Thanks! I'll order those asap and hopefully fix my left side auto-leveler at the same time.
Old Apr 19, 2018 | 11:03 AM
caverman's Avatar
caverman
Throwing out an idea here. I just had the headlights on my GS restored a couple weeks ago and it had moisture on the inside. The person that restored them to told me to pull the bulb and let it sit for a while and the moisture will evaporate. I went out the next morning to do that and the moisture was already gone. Then we were talking about changing the HID bulbs over on the LS forum and it was mentioned that there is a rubber seal around the bulbs. After so many rears and miles that rubber seal can go bad especially if you ever touch it like removing the bulb. So, maybe there is a rubber seal around the bulb that could be replaced?
Old Apr 24, 2018 | 07:31 AM
KyleH's Avatar
KyleH
__________________
Interesting I've never noticed a green tint nor do I notice it on these. However, how can you differentiate the HID housings from the standard halogen housings? These look just like mine (halogen).
Old Apr 24, 2018 | 09:59 AM
lyonkster's Avatar
lyonkster
Yeah, the green tint is hard to see in some lighting, but really jumps out in other lighting. The housings are completely different between HID and halogen, only the lenses are interchangeable. I once bought a set of halogen lamps just to swap the lenses, that was way more effort than it was worth. As to how to differentiate, just go by the description of wherever you're buying them from, they should state halogen or HID.
jeffhoward
Dec 29, 2017 07:50 AM
191185
Mar 27, 2011 07:14 PM
SC400_408
Mar 1, 2007 12:23 AM
Sun3rgy
Jul 27, 2006 08:21 PM
gapxguy
Aug 27, 2005 02:20 PM
