Is this a good price for aux in?
So I have a 03 GS430. I want to add a aux so i can play my music from my phone. I called car toys & dey quoted me $300 to do dis. Should i pass or grab
Listen to firelizard, he is right.
Maybe this is what you want?
Select Toyota Lexus 98-05 Auxiliary Input Adapter Kit
Specs:
- 3.5MM phone jack fits any MP3 player, Smartphone
Factory harness connects to the stereo
Best sound possible. Not FM transmitter!
Most Toyotas, Lexus and Scions supported (year 98-05)
In-dash 6-CD will remain working!
SKU: TOYOA1
Specs:
SKU: TOYOA1
So what installation did you have to do. How do you work it. Is connected to the radio like a transmitter or taking out anything in the dash?
You should buy a aux input port, run a small amount to wire from the aux input port to the cd changer plug and burn a blank disc with complete silence on it in a cd slot. For around $5 you can have a aux input that looks factory if you mount it like I did and sound great. I avoid Bluetooth as most cheaper Bluetooth adapters compress the audio.
If we're just going to link to DIY setups, I did JayNunu's on mine, which is better than that blank CD business and my input jack is actually on the head unit.
https://www.clublexus.com/forums/gs-...-headunit.html
you hit the cd changer button to alternate between the cd changer and the grom, and they're both fully functional. the grom wakes up and connects in maybe two seconds. i totally prefer it over an aux cable just for the ease of install and even more so for the wireless capability
you gotta take the head unit out to access the cables in the rear, and its just two or three plugs after that. i think the cable running to/from the cd changer now gets plugged into the grom, which in turn will now plug into where the cable from the cd changer used to go, so the grom is installed in-line. might be a third cable for power, but they're all easy to to figure out
https://www.clublexus.com/forums/gs-...l#post10450313
