Are these two sensors the same?
Squashing the last few gremlins on the new motor.
Can't get the shift indicator lights on the dash to work and the car won't shift out of park unless I depress the override. I replaced the shifter and linkage as the neutral safety switch as well. A friend suggested that the speed sensors on the tranny might be the culprit. I ordered one (the one near the front of the trans but not sure if the one at the tail is the same. Anyone know? Any general hints/tips would be appreciated.https://cimg3.ibsrv.net/gimg/www.clu...8f62eb6d09.jpg (Tranny pic from previous motor) |
Originally Posted by Mr Jokster
(Post 10040316)
Originally Posted by Alphaman19
(Post 10041631)
Thanks. The issue was the positioning of the neutral safety switch. That thing's really sensitive. As I rotated it slightly while wifey sat in the car, I could here the tranny "click". Once I knew the gear associated with each adjustment of the nsw, I tightened the bolt down and was done.
Good going... And a big thank you for posting your resolution along with posting a killer picture of your swap in progress. If you didn't mind me asking, what happened to the original motor and where did you source the new motor? |
Originally Posted by FrankT
(Post 10041853)
Good going...
