I'm getting ready to put a 2JZ-GTE Artisto engine into an E-30.
Do you guys recommend in particular that has the recommended parts that essentially are needed to give the engine a refresher? And do you have anything that you would recommend not over looking before putting it into the vehicle.
wiring to your oem dash if you haven't already started looking over it. you will probably need to look this over with a fine tooth comb. if you don't already have one, I suggest a decent soldering iron and plenty of heatshrink if you're going to DIY
How many miles on the engine?
Oil analysis results?
Cranking pressure?
Leak-down test results?
What power level is the goal?
The typical purchase from a engine supplier. It's from JDM NY, if you have had any dealing with them. I'm switching it to single turbo, so right now...just going over a parts list of what's needed, and getting ready to pull the engine itself apart.
