ECU problems
Old Aug 21, 2017 | 08:32 PM
bulltproof's Avatar
bulltproof
Default ECU problems
Hello,
I recently purchased a 2000 GS, the owner said the ECU was possibly bad. I am not receiving any OBD codes, nor will it connect. The car will turn over, but no start up. I tried a second ECU, with the same model, and it wont connect with OBD either. Could be both ECUs are bad? Maybe someone can help. Thanks!
Edit: OBD fuse in driver kickpanel fusebox is not blown.
Old Aug 21, 2017 | 09:39 PM
TW99GS300's Avatar
TW99GS300
Sounds like there are some wiring issues.
Have you checked the EFI fuse in front of the battery?
Wilbro666 has a full wiring diagram for the GTE that you can use as consideration if it's a GS300. Lextreme may have the GS4 diagrams. Good luck
Old Aug 22, 2017 | 05:21 PM
vijayn's Avatar
vijayn
Yer like TW99GS300 said, its probably a wiring issue / blown fuse.
Sounds like the ECU isn't being powered up because the engine wont start and theres no connection to obd. Ecu cant connect to obd if its not powered up.
After checking all relevant fuses, you need to check all 12V and 0V wires going to the ecu.
Apaul
RC F (2015-present)
14
Sep 25, 2018 05:28 PM
bowen.chau
RX - 1st Gen (1999-2003)
Nov 28, 2010 01:36 AM
drewmack
Nov 29, 2006 06:21 AM
black sc
May 16, 2005 12:17 PM
