Does this drivetrain play look/sound normal?
Just bought a new '98 GS400, 111k miles, dealer maintained, no codes, runs and shifts strong. Body has some scratches and hail damage so I got what I hope turns out to be a good price. It has a pretty severe vibration at high speeds, get noticeable maybe around 50 and by 80 I'm shaking in my seat. It seems load dependent - stronger under accel and decel than cruising. Mounts and CVs seem OK, the vibration damper is a little cracked and I'll probably replace now but doesn't seem terrible
The center support bearing seems to allow quite a bit of play but the rubber is solid and shows no signs of cracking anywhere, so I assume its supposed to behave like this? When I wiggle the front shaft though I hear a noise which seems to be the splines moving around. It looks like a sort of compression fitting to me, anyone know if that's the case? If so, should I try to tighten it up a bit or better to leave it loose so it slides? Here's a video of what's going on there.
Just went through this myself (actually, it's a common occurrence on the 2GS) and it turned out to be warped rotors. I had a vibration at 60mph that would go away around 72mph while cruising. Nothing around 45mph. Get your rotors turned / wheels balanced and see if that helps. I also had a bent rim once that contributed to the shake.
Yeah, same here...no vibration during braking. But if you're at 60mph and you can see the passenger seat head rest shake that's a sign. Btw, usually the shop would say the front rotors are the culprit.
Sweet, that'd be nice. Headed to Harbor Freight to grab a runout dial now...
I wish I had a chance to test drive it longer, it really seemed like it was worse accelerating or decelerating which wouldn't make sense if it wasn't in the drivetrain. Hope I'm wrong.
.003" runout on both front and rear drivers side, same with variation in plate thickness, both within standard spec. I don't think it's a rotor issue.
Anyone out there yanked on their driveshaft that can say if I appear to have more give to it than I should, or if that spline connection should be tightened??
the problem is coming from the driveshaft. inspect further. pull it out if you have to and double check the u joint in the middle. plus you need to pull the splined section out all the way and clean out all that rust and buy the specific grease thats made for drive shaft splines, than reassemble with new u joint and attach a new clip to keep that boot on securely.
Thanks for all the replies, after some convincing I swapped the tires and rims from my 99 LS I'm parting out onto it, and the vibration is almost gone. They all looked good visually except a small amount of dry rot on the rears too.
One of my CVs has noticeable runout which measures roughly .040" in the middle which is not ideal, between that and the various other things in the drivetrain which are nearing the end of their lifespan that's probably the remaining bit of driveline vibration I'm feeling. After all the reading the last few days I now know how to replace every chassis component on the vehicle, so there's that anyway. Love it when it's an easy fix.
I had my doubts about the driveshaft.
holy hell!!! there is something seriously wrong with your subframe mounts and lower control arm spherical bearings. notice how in the beginning of the video while making it happen your entire wheel vibrates out of round. and also the rear lower control arm where it mounts to the subframe is also vibrating and moving? yikes.
