CNC adapter for gs350 brake calipers
So I got a diagram or a blueprint for an adapter to fit 07-11 gs350 4-piston calipers on our 98-05 Gs. Im willing to give it up to anyone who could also machine a pair for me at no cost. (I'll pay the shipping)
*these brakes are are better than ls400. Much sharper. |
Top bolt lines up perfectly bit bottom bolt will need to have an adapter braket made. Everthing else bolts up.
So to mount these brakes the following will be needed: 07-11 GS350 calipers, brake pads and rotors off of the same car/model (07-11 Gs350, 430, 450), and adapter brackets. |
Originally Posted by sladkix
(Post 9853849)
Originally Posted by firelizard
(Post 9854464)
you mean you'll give up the plans at no cost, not that you want the parts at no cost, right?
How much are you willing to pay for them? I'm sure an enterprising machinist would make a run of them if enough interested people could make it worth their time. I would consider doing this instead of an LS400 swap. What clearance issues are there? Does it fit without RCAs in the factory 17" wheels?
Im pretty sure it fits 17" barely any clearance left but it does fit. Rca's not needed.
just to clarify, they fit in gs350 17" but Im not sure about 98-05 gs 5 spoke 17" https://cimg5.ibsrv.net/gimg/www.clu...c98be6d217.jpg |
(Post 9854486)
I am I the process of doing the same and have to fit the GS350 calipers on the 2Gen GS. Try AtlantaWaterJet.com, they are the ones that made some other brackets for me.
I decided to spent some time on this since the GS350 brakes is much bigger than the LS400 and even the Supra TT. I know I have all three sets in my hands now. Also they are of a newer design and does not need RCA adaptors to clear. Let us get this rolling. I should be done with my design in a few days.
Originally Posted by BiGEZ
(Post 9855461)
also if these can be made to adapt then the F-sport Caliper should work also as it is a upgrade for the Gs 350 |
They are all 4 piston calipers. The LS400 are the smallest rotors (315mm) , TT Supras are larger (323mm), and GS350/IS350 are larger but only by 11mm. This divided by 2 gives you only 5.5mm or 0.212 inches material of metal added around the edge of the rotor for leverage/surface area vs. the Supras. ISF rotors are 360mm.
The G/IS/350 calipers look better for sure, might be lighter, might have less brake fade, but how much is the question, marginally so? I just wanted to give some data here. I have the Supras because I didn't want to add any extra pieces of metal to my suspension, such as RCAs or brackets. They have more than enough stopping power, and with Pilot Super Sports, the deceleration is brutal. It should also be noted that you won't feel the difference in hard stopping when limits of the tires are reached with all season/non-sticky tires with any big brake setup. So even 3GS brakes with bad tires will be worse than LS400 with sports tires although the fade is questionable and hard to prove back to back |
What is the construction of the GS350 calipers, steel or aluminum?
Originally Posted by GS400V8
(Post 9858207)
Originally Posted by Wrath
(Post 9858216)
No problem! Some more info to keep in mind is the 3IS weighs 100lbs less than the 2GS and 4IS can be 140lbs lighter. The 3GS is even 200-300lbs heavier than the 2GS!
Also, the 2001 models had a larger piston bore for the master cylinder, and the 3IS/3GS probably got it upsized again. This alone would affect the pedal feel combined with the IS350 you drove being lighter than any other cars. |
