ABS sensor
Hello everyone,
I replaced by suspension and I believe i messed up my ABS. Wanted to know if anyone had any pics of the location where the ABS wire plugs into on the BODY. I am going to take the sensor out again and see if I can clean and reattach it. If that doesnt work then I may need a new sensor. I know which one it is because the passenger side is the only one I pulled out of the Spindle. Any help would be much appreciated. I have searched for pics but alot are no longer working because the host is bad. Thanks again |
It snakes to under the front side of the inner fender.
If I'm correct you gotta pop some of the protective plastic cover/shielding off first. Just get under the car and trace it from the spindle. It's about as hard as trying to see the backside of your elbow :) Good luck |
i know there is probably a much better way to know exactly where it connects to. sometimes when i am lost i reference pages like http://www.lexussouthatlantaparts.com/
and search the part- they usually provide an image which somewhate helps where things are located or connected to. just my 2 cents |
