Question about the rear inner fender well
Old 01-09-15, 07:32 PM
Aristo722
Aristo722's Avatar
Default Question about the rear inner fender well
Ive done a pull and roll on my fenders as wide as I can get them, but some people say you can cut out the inner part of the rear fender well for clearance, but dont take a hammer to it. (will leave tons of dents/dimpels) so im curious if anyone has done it. If so, could you lend any advice? What to do, what cutter/wheel to use. Any precautions. If its not to bad, I plan to do it. But if its to much of a hack job, Ill pass. Just a thought.
Old 01-09-15, 11:56 PM
NorthStyle
NorthStyle's Avatar
I'm confused... if your fenders are rolled and pulled, then the lip inside the rear fender that everyone is referring to should already be flat.
But, to answer your question: I marked off the area I wanted to shave down with tape, shaved it using a cutting disk, sanded the edges once the cutting was completed, then followed up by painting the cut edges to prevent rust. There is a DIY here on the forum though.
Vishuz
04-17-12 11:13 PM
actv8d
02-05-11 08:57 AM
Retrospect
07-08-08 05:22 PM
dizazndude
Suspension and Brakes
03-13-08 02:21 PM
JspecSC3
06-22-07 07:08 PM
Quick Reply: Question about the rear inner fender well
