ECT/PWR button doesnt seem to work
Old Dec 15, 2014 | 03:51 PM
alexgtr's Avatar
alexgtr
Default ECT/PWR button doesnt seem to work
The ECT/PWR button doesnt seem to have any effect on my car. When i press the button the light does not come on the dash either, the same for the VSC light.
I have pulled the gear surround off and checked to make sure they are all plugged in which they are (heated seats work).
Any ideas? Are there any fuses anywhere?
Its a GS430 btw.
Old Dec 17, 2014 | 03:02 AM
sam12345's Avatar
sam12345
Broken wheel speed sensor wire. Did you recently do suspension work? Did you run over something? Check fuses first. Also the led light that eliminates the switches could be bad. Take off on a nice level road at part throttle and notice the shift rpm for each gear. Go back to same spot and turn on ect button, take off in the exact same manner noticing the rpm each shift occurs. Is the rpm higher with ect switch on? If it is ect is working. Now do the same with snow on. It should change at lower rpm and feel like a loss of power, if so it's working. Slam on your brakes, is abs working? Then your sensor cables are ok. Turn corner very fast, do you hear a beeping sound and is your power attenuated? Then VSC is working. Push VSC switch once. Turn corner fast. Does your tail swing out, no power attenuation, no beeping then VSC switch is working. Search for how to fix led lighting if everything works. There is diy on fixing the lighting somewhere on this forum
Old Dec 22, 2014 | 02:29 AM
alexgtr's Avatar
alexgtr
I pulled the dash off and there was some black tape of the bottom set of lights so the buttons are working. Also, my VSC Off and VSC lights are on.
My mate plugged in a scanner and it came up with error C1336 - Zero Point Calibration for Deceleration Sensor Undone.
I tried the jumper fix loads of times and it just wont get rid of it. Is there are fuse for the YAW sensor anywhere? I have checked all the fuse boxes i can find (two in footwells 3 in engine bay) and cant find one that jumps out at me.
Old Dec 22, 2014 | 07:02 AM
sam12345's Avatar
sam12345
Sounds like s bad sensor. Do a search for that error code
https://www.clublexus.com/forums/ls4...c-vsc-off.html
posterboi
Feb 20, 2022 07:20 AM
dirtracin1
Apr 2, 2014 04:16 PM
MartijnAms
Jan 14, 2014 05:27 AM
D-Boi
Sep 30, 2010 08:52 PM
hubbard316
Performance
Jul 28, 2001 08:51 AM
