Might be buying a GS400. Few Questions
Hello all. Current LS400 owner here. I'm about to sell her to purchase a GS400 as I want the same reliable motors but a little more speed.
I went to look at her last night. 185k with new timing belt, seals, spark plugs and valve covers. The water pump was not replaced. Is this something to worry about? My current 96 LS400 is about to hit 250k and still has the stock water pump.
As with nearly all GS models I've looked at, the radio is all messed up and I can't read anything it says, but that can be fixed by putting in a different unit.
The exterior was a good 9/10, and the only interior issue other than the radio was cracks in the driver seat. Which I didn't care because I plan to get some Clazzio covers anyways. The floor mats are ugly as heck as well but that can also be cheaply fixed.
He said it had a P0446 code but isn't that always a loose gas cap? The CEL came on when I inserted the key, and went off when I started the car. As a car with no issues would. So I'm assuming that's what the issue was and it just resolved itself?
Also, I've noticed this on all 3 GS400 I have looked at. The shifter doesn't seem to want to go as smoothly through the gears as the shifter in my LS does. Is this just a thing with the 5 speed autos? I thought maybe it's so you don't accidentally knock it in and or out of gears. Especially since the GS has a manual mode.
I am very set on getting it as soon as my car sells. Sadly I thought I already had it sold but leave it to a flaker to give your hopes up. :/
Other than the power steering issue with the 1UZ, is there anything else to worry about with this motor is a GS? Other than getting tickets ^_^
I think you'll enjoy the change. I love my GS400 to death, and I've only had it a few weeks.
I have a '03 GS 430 at 120K and am looking at the timing belt - dealer estimate under $700 and they did not try to up sell me to do the water pump and I'm not sure what to infer by that other than if they had half a reason to do it they would have recco'd it. Only thing they mentioned was I needed spark plugs - imagine spark plugs only lasting 120K miles
It's changed as a precautionary measure. The only reason I could see your dealer not quoting you on a water pump replacement, is to wait until it actually goes bad, thus charging you to rip apart the front of the engine again. Contrary to popular belief, the water pump will 'call it quits' long before the belt will.
C8V6C
05-11-12 08:35 PM
