Aristo headlight vs usdm gs headlight info
Old 09-24-14, 06:18 AM
flipside12
flipside12's Avatar
Default Aristo headlight vs usdm gs headlight info
So im looking to replace my headlights on my 430 which have oem hid/auto level. I found a mint set of headlights from an aristo with oem hid/auto level.
My questions are, being aristo is rhd how will this affect light output/hid cutoff? Will it be plug and play? Are there any issues ill come in contact with? Thanks club lexus
Old 09-24-14, 06:28 AM
NorthStyle
NorthStyle's Avatar
Short version: you'll blind oncoming traffic. They'll be fine if you're doing a retrofit since you can purchase a set of LHD projectors. New [LHD] OEM can be bought on ebay for around $500 or less shipped if you search hard enough.
Old 09-24-14, 06:36 AM
flipside12
flipside12's Avatar
Is there no way to adjust?
Old 09-24-14, 08:10 AM
NorthStyle
NorthStyle's Avatar
I know it's done in the UK and Europe for the guys who've purchase/import RHD/LHD cars (dependent on country), but I'm unsure how they go about accomplishing it.
Old 09-24-14, 09:42 AM
newgsman
newgsman's Avatar
I have them in my car. Never had anyone flash their highbeams at me because I was blinding them...
I did adjust them using the normal adjustment screws. Didn't have any light beam alignment machine so I did it by looking at the beam pattern on a wall in front of the car. Been two years so I guess I did an ok job.
Old 09-24-14, 10:15 AM
flipside12
flipside12's Avatar
Sweet exactly what i wanted to know, this set is alot cleaner then the usdm seti found
Old 09-24-14, 12:24 PM
newgsman
newgsman's Avatar
Everything is plug and play. The only thing with the JDM lights is they don't have the bubble level gauge on top. I don't think that's all that important. As far as I know those things just help you manually get the lights to a level setting (not absolutely required in order to make the initial level adjustments). After that the auto-level system keeps them level while driving.
Old 09-25-14, 01:28 AM
Lutkis
Lutkis's Avatar
I wouldn't recommend the Aristo lights without a retrofit.
I don't understand why one would intentionally cause harm to fellow motorists when there's legit options available.
Old 09-26-14, 05:37 PM
SC4Paulo
SC4Paulo's Avatar
pics of aristo headlight?
Old 09-26-14, 08:17 PM
NorthStyle
NorthStyle's Avatar
I'm with you 100%.. but we've gone over this before in the last thread and people are still recommending others to do this
Old 09-26-14, 08:41 PM
Kyle Harty
Kyle Harty's Avatar
You could get the aristo lights and switch the reflector bowls to USDM ones. A bit of a hassle to open the housings just for that (if I was going that far I'd strongly recommend a retrofit, the stock hids suck) but it'd be an option to use the clean housings without the incorrect cutoff. If you do want to go that route I've got a set of bowls laying around you could have cheap.
Old 09-28-14, 01:00 PM
flipside12
flipside12's Avatar
i do plan on doing a retro in a few weeks, are your bowls hid? pm me prices, that would take alot of the prep time down if i had a set i could retro and throw in quickly
AZ JB
02-13-16 08:02 AM
fstlane
01-20-12 01:35 PM
deknick
GS - 1st Gen (1993-1997)
113
08-02-11 02:07 AM
swat1727
11-06-08 11:01 AM
Quick Reply: Aristo headlight vs usdm gs headlight info
