intake help! ran into a problem
Old 09-09-14, 05:18 PM
itztwinki3
itztwinki3's Avatar
Default intake help! ran into a problem
So i bought an intake last week finally came in. I have a 98 gs300 the intake was specified for 98-00 gs300. mafs fits so its the right piping. so while installing it I've noticed that the OEM intake has 3 vacuum lines as for the one I bought has 2 holes for 2 vacuum line. what do I do now? Do i put a breather on one of the oem ones?
Old 09-09-14, 05:21 PM
8ll8lack
8ll8lack's Avatar
get a T fitting from the auto store.
Old 09-09-14, 05:37 PM
itztwinki3
itztwinki3's Avatar
can you get me an example picture of how it looks please?
Old 09-10-14, 07:02 AM
armanitran
armanitran's Avatar
Google it. T-fittings all pretty much look the same. Like a "T"
Old 09-10-14, 09:53 AM
8ll8lack
8ll8lack's Avatar
pick Y or T fitting that suit your needs with your sizes tubing.
Old 09-10-14, 10:18 AM
itztwinki3
itztwinki3's Avatar
okay now I encountered a new problem after installing the intake I start the car up rpm keeps jumping feeling like its going to stall. what can it be....?
Old 09-10-14, 10:25 AM
MikeFoxx
MikeFoxx's Avatar
have you cleaned your MAF sensor?
Old 09-10-14, 10:49 AM
offbad
offbad's Avatar
if directly related to the install, sounds like dirty MAF
could also be if you had reset the ECU or disconnected power the car is still trying to find itself.
Old 09-10-14, 11:35 AM
itztwinki3
itztwinki3's Avatar
I clean the maf and cleaned the throttle body. I install the intake hesitation like gone stall. took it apart put back the oem one and it went away. I reset the ecu and everything.
Old 09-10-14, 12:33 PM
boostedsi
boostedsi's Avatar
did you kink one of the vacuum lines? put the maf pointing in the right way? is all the couplings on tight no air leaks?
i would check all of that, it should work fine
what kind of intake is it that you bought?
Old 09-10-14, 01:11 PM
offbad
offbad's Avatar
right, make sure the MAF is pointing the right way
and also make sure you have the rubber gasket for it as well.
Old 09-10-14, 04:19 PM
itztwinki3
itztwinki3's Avatar
no kinks at all, maf facing correctly. coupling and maf gasket sealed pretty well. injen
Old 09-10-14, 04:40 PM
itztwinki3
itztwinki3's Avatar
heres the real question about how to install properly. which 2 hoses to I put together on the tee splitter? the one going to the valve cover and the one going to the head? or?
Old 09-10-14, 05:46 PM
boostedsi
boostedsi's Avatar
Try this
http://www.injen.com/galleries/produ...ate8-23-11.pdf
Old 09-11-14, 11:07 AM
itztwinki3
itztwinki3's Avatar
but I have 3 hoses from oem. the diagram for is300 shows 2. I doubt that would work.
Quick Reply: intake help! ran into a problem
