Ok, I got the alternator and battery replaced. Warning light still on. Do I have to drive around for this to disappear or what would you guys recommend as the next step? Thanks in advance!!!!
Pull the ecm fuse for a short while or disconnect the positive terminal from the battery and touch it to the negative post to discharge the system/capacitors. Then reconnect battery and should go out. Or you can have an auto parts store clear it for you for free.
While I did clear most of the codes with new battery and alternator, I checked the abs sensors on all four wheels. The rears are good but front are both dead. I ordered them and waiting for delivery. I will keep you posted. Thanks again for all the help. You guys are the best.
bumping this thread i seem to have the same problem. I replaced my gas cap and nothing.. Im getting 15 codes for evap and one for the brake master... Ill check my battery and alternator at work today.. The only thing i am experiencing with braking is the first tape of the brake it bites very hard. The next push after fine. I do hear a small wheel bearing noise from the right front but i doubt that would have anything to do with my evap codes and brake code
